hey..
recently got my hands on a hks ssq rice off valve.
i want to install it myself but i've heard that its best to get it done by someone who can actually tune it to work efficiently (PFC) instead of causing backfire/stalling issues.
is this also true with the ssq as i've also read something or other about how its different to most bov's and dosnt leak and so on.
https://www.sau.com.au/forums/topic/38292-bov-installation/
hey man the installation of the BOV is soo easy that it is not funny. Do u have the r33 Flange? If you do then its a 15min job. Yes it is true, the HKS blow of valve will not leak under any ammount of pressure. This is because it is the only pulley-type blow off valve which is emune to this.
Chris
https://www.sau.com.au/forums/topic/38292-bov-installation/#findComment-774473
that black pipe is your recirculation pipe, goes back into the air intake just before the turbo. You can just block that off. With the stalling you should not have a problem if the spring is set tight enough. If its too loose the piston will not close before the throttle and you will stall. If you can see the piston from the outside of the BOV, rip the throttle so the BOV goes off and watch the piston on it. The piston should be completely closed about a second before idle.
Do you have an exhaust? if so you will prolly get backfire not matter who fits it. From what i have heard/been told the skylines run a bit rich from the factory causing backfire and an exhaust will act as a bit of a microphone for that :) I had a BOV before exhaust and did not get b/fire, put an exhaust on and got it. Sorry bout the length.
Steve
https://www.sau.com.au/forums/topic/38292-bov-installation/#findComment-780249
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
