Hi All,
just wondering what kinda car you would all prefer for drifting and why, i have done a little reading about them and i read that R33's arent too bad because the weight is quiet evenly distributed throughout the car but also i saw someone saying the R32 is better, i dont know why though, if i got the R32 i would most likely put the RB25DET in it with the standard ceramic turbo for the mean time and run it at 9PSI koz at first it would be pretty standard, just the usual mods like FMIC, 3" HI Flow cat back, strut bars and coil covers oh an probably put a HICAS Lock bar in it too.
but yeah at the moment i have an R33 thats mildly modded but i dont want to ruin it because its my daily, but if someone can tell me what kinda car would be good and why that would be great, i want to stick to nissan's though.
also someone said 180sx apparently isnt that great because there not so easy to a beginner for drifting.
Thanks all =]
https://www.sau.com.au/forums/topic/383231-best-drift-car/
33s don't have a lot of lock so you'll need rack spacers straight up, best mod I ever did to mine.
There is a f**king PRIME R34 GTT with a 3076r and log booked cage on MY105.com I'd get that if I had to do it all over again. That car is ready to rock!
I like the why my 33 moves on the track, but I've not had a lot of time behind the wheel and I haven't driven many other cars. in my 33 the pivot point when sliding feels like it's right on the gear lever which just feels right for me.
As long as you're not 100% talent free you could drift almost anything (with in reason) given a few hours behind the wheel.
I don't care what anyone says. Drifting is the hardest thing ever, I consider my self a pretty OK driver and my lap times reflect as such, but when it comes to drifting, I'm fkn terrible :P But I'm getting better for every run I do.
https://www.sau.com.au/forums/topic/383231-best-drift-car/#findComment-6113204
yeah i want to spend minimal money though, so i dont mind buying an old track car and fixing it up a bit for drifting, i dont think i can afford a R34, hopfully one day i can but i would use it as a daily lol.
then buy a 2nd for racing.
thanks for the advice though =]
https://www.sau.com.au/forums/topic/383231-best-drift-car/#findComment-6113692
I'm assuming you're just starting out? and wanting a track only? , for value to $$ you can't really go past a r33 , they have a strong driveline and are cheap-ish for parts and there's an abundance of wrecked ones out there . i always go by the rule: if you can't walk up to your car and hit it with a 10p hammer than your best not trying to drift it , starting out it's not a matter of if your going to damage it , it's when! . next best from r33 arguably would be a series 1 s14 possibly not as reliable due to the gearbox strength mainly .
try finding one with a decent drivers seat and a aftermarket diff , also the r33 steering rack is the worst out of all nissan for lock , best swapping it for a s14 rack as they bolt in very easy
Edited by toffy
https://www.sau.com.au/forums/topic/383231-best-drift-car/#findComment-6114577
  • 1 month later...
  • 5 months later...
  • 3 weeks later...
If your drifting, start off with a standard car, minimal power to get your driving down pat. Just make sure you have the diff tightened/shimmed or get a 2way, some decent coilovers and a bucket seat to hold you in... Get used to it and progress with mods from there depending on how the car reacts... Plenty of people drifting 32/33/34's.
https://www.sau.com.au/forums/topic/383231-best-drift-car/#findComment-6423153
  • 2 months later...
Just my2 cents, i've drifted a 400hp R33 & it was fun, had all the goodies like coilovers and adjustable arms. Then i transplanted the complete driveline from the R33 into a S13 Silvia.
F##K me what an easy chassis to drift. Had to order custom springs for the new coil overs 10kg front 8kg rear, no extra cost with BC's to compinsate for the extra front end
weight, no over steer in mine.
This beast runs 12,s down the strip, drifts like a machine, & circuit races with the best of them.
The R33 brakes with this combination are awsome, i have added steering rack cnc machined spacers for extra lock & i am over the moon with every aspect of the ability of the S13 Silvia chassis.
I have been in only one better drift car & it was a mates 330klw Ls2 S13 silvia with all the best drift bits & i wish i could afford the tyres it demolised, two new rears every three
laps of eastern creek. LOVED IT. Go to Revtune racing to view some vids of it including a couple of vid,s of my puny liitle RB25 powered S13.
https://www.sau.com.au/forums/topic/383231-best-drift-car/#findComment-6531485
  • 1 month later...
  • 2 months later...
Okay just an update:
just bought myself a sil80 with these specs:
Engine Modifications
Nistune
Apexi Pod Filter and Adaptor
Z32 AFM
Power Enterprise 850cc Injectors
Garrett GT2871r with 0.64 rear housing (very responsive)
Braided turbo lines
Cancelled BOV
Tomei Rocker Arm Stoppers
Tomei Poncams and valve springs
Full 3” exhaust with decat
Flipped FMIC (short pipes, less lag, more response)
Front mount oil cooler with oil filter reloc. kit,
Catch can
Exedy Heavy Duty Clutch
Big fuel pump (cant remember exactly what it was)
Thermo fans
Suspension
Cusco Front coilovers
KTS rear coilovers
Drift Pineapples
Front and rear strut bars
Monkey bar/floor brace
5 stud front with s14 brakes
Locker diff
All Adjustable Suspension Arms
R32 GTR Sway Bar
Interior
Stripped out
Nardi
Oil Pressure gauge
R32 seats
Body
Brick headlights
Bonnet pins
Rare Duck Tail Wing
Aftermarket Rear Bar and Skirts
No Front Bar
compression test = 140PSI on all cyl's
its all ready for the track just need to replace one tyre.
only bad thing is that 2nd crunches so im guessing thats a syncro, so eventually buy a new g/box
https://www.sau.com.au/forums/topic/383231-best-drift-car/#findComment-6706325
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
