The question my friends is,
Will a 19" wheel with 15mm offset fit a 33 gtst??
http://www.ebay.com.au/itm/XXR-522-19-19x8-5-5x114-3-5x120-15-CHROMIUM-BLACK-WHEELS-RIMS-350Z-370Z-G35-G37-/320790554079?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ab09b65df#ht_3429wt_1139
WILL IT FIT... WILL IT FIT...
Edited by Flynnn
https://www.sau.com.au/forums/topic/383547-19-with-15mm-offset-fit-a-33-gtst/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
