  • Replies 5.5k
Posted Images
also, for your enjoyment
the new mclaren front end
ver nice. LM-style vents over the front wheels are cool. can't say I've ever liked those optional wheels, but nothing a set of HRE's or similar wouldn't fix.
75hp is a not-inconsiderable increase. would run sub 3 sec to 100 for sure with 667hp and some corsa tyres.
at 660hp+, 1400kg, with 200mph+ top speed, 3 second 0-60 and a price tag of £168,500... this is the car to have
bang for buck, its almost unbeatable
except they are only making 5 of the HS models to keep them exclusive :blink:
Speaking of collecting shit
A lot of teams are selling their 2011 apparel and merchandise at a massively reduced price if anybody is interested. I know Mclaren is 50% off almost everything... sh@un...
which sites do you recomend for cheap merch
Is that at a specific shop? RBR prices all seem the same
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
