  • Replies 5.5k
Posted Images
Surely this is the nail in Massa's coffin. Perez may as well park his Sauber in the Ferrari garage after this race
ferrari are probably packing up massa's stuff right now. massa will come into the pits to find all his stuff in boxes out the back of the pits
