Wonder if Vettel is wishing he took the new exhaust now...
Sebastian Vettel said he has no regrets about his decision to stick with Red Bull's old exhaust design, despite going out in Q2 for the first time in 43 races.
The world champion decided to use the old exhaust layout for the weekend, while his team-mate Mark Webber opted for the latest?-specification unit.
Vettel failed to make it into the top 10 in qualifying for the first time since the 2009 Brazilian Grand Prix.
The German said he was happy with how he had performed during qualifying, but he conceded that his times were simply not quick enough.
"It's always easy to say this and that now, but I was happy with the car yesterday and that's why I decided to stay as we were," said Vettel.
"I was happy with the laps I had in qualifying. There were no mistakes, but they weren't quick enough. It's as easy as that.
"Yesterday I was happy with the car. We decided to stick with the current settings and I don't want to blame it on the car. Three times I did exactly the same lap, and three times it wasn't quick enough to make it into Q3."
Vettel admitted he was disappointed to be starting from so far back, but he reckons he still has a chance to put on a good performance in? the race.
"Obviously I'm not happy," he added. "As I said, I was pretty happy with the laps I had in Q2, but they weren't quick enough. We have to start the race from P11 and see what we can do tomorrow. Surely it makes it a bit harder, but not impossible to do a good race.
"I was pretty happy with the car today, but it was pretty close. Unfortunately we weren't able to take the final step. There's a lot of work to do, but there's a very long race tomorrow, which gives us lot of chances."
Team boss Christian Horner downplayed the difference between one exhaust layout and the other, saying the gap between Vettel and Webber was not necessarily down to it.
"Not necessarily. The characteristics are slightly different but it's hopefully suiting both drivers' different driving styles," Horner told Sky TV. "If you look at the first and second sectors there is absolutely nothing between them, so the difference seems to be in the third sector."
http://www.autosport...rt.php/id/98809
lol, what he means is a3863053-114-male19-male-crying-tears-smiley-emoticon-000061-large.gif?d=1300008028
Pastor Maldonado and Pedro de la Rosa have been given reprimands for impeding other cars during qualifying for the Chinese Grand Prix.
http://www.autosport...rt.php/id/98829
  • Replies 5.5k
Posted Images
Wow,this is turning out to be the best season.The fastest cars in race trim cant make the top 5 in quaily.Thats always going to make the race interesting. Then youve got Saubers and Lotus up the front,I think its fantastic.Dont count Mark out just yet,the Mercs will burn their tyres,Mark should be able to get past the Saubers,Kimi could be a problem?So come on Mark,get that thing off the line and youre a good chance for a podium or you never know dare I say a win.
Anyone know what the stream for HD will be for the Race?
Not keen on missing key stuff from another failed One telecast
Just run live timing and you can piece together what is happening from the times and the highlights commentary on the side.
Jean-Eric Vergne will start from the pitlane for the Chinese Grand Prix after his Scuderia Toro Rosso team made changes to his car overnight.
Following a disappointing qualifying performance, Toro Rosso changed the floor, barge board, floor to rear wing spacer, nose barge board, sidepod wing, T-tray, sidepod inlet and ballast.
As these parts are different to the ones that were originally used, under parc ferme regulations it means that Vergne will not be able to take up his 18th place on the grid, so must start from the pitlane.
http://www.autosport.com/news/report.php/id/98849
I really hope Kimi can get a result today. You have to think looking at the front row and the straight line speed of the Mercs, they will have a pack of cars behind them into the first stop and the likes of Webber will need to 3 stop to get soem free air and hammer.
Has the potential of being a cracker!!!!
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
