  • Replies 5.5k
Posted Images
As for why Webber feels more comfortable in the updated car, Marko added: "Mark is less sensitive to the [car's] behaviour. He just needs four wheels, but it's different for Vettel."
what he really needs is wings
RANK TEAM NAME POINTS 1 1 au.pngWebbull 183 2 1 au.pngSau 166 3 3 au.pngNubs's army 125 4 1 au.pngNJSracing 116 5 2 au.pngJteam 112 6 2 au.pngstR33ter 109 7 1 au.pngKimiUmp 108 8 1 au.pngDori34Racing 102 9 2 au.pngLooptrooop 101 10 1 au.pngFishos 97 11 1 au.pngMissileman 89 12 4 au.pngMacGillaZ 81 13 1 au.pngScottydoo Racing Mega Predictor 74 14 au.pngScuderia Dezz 73 15 au.pngSniper Racing 71 16 3 au.pngN1GTR 63 17 au.pngmad082 27 - au.pngOZHCR32 0 - au.pngSMc_F1 0
i'm last of the point scorers, but the chinese GP was the first one i did
Of course not, he is the driver essentially on the out. Unless after 3 more races and Web's is higher in the points scale and performing better etc - then it'll still favour Vetool.
Don't forget that Web's has only really risen back to the spotlight so to speak because Vetool is not performing, combined with the flat tyre etc. I think it's still way to early in the season for RBR to make Vetool play 2nd fiddle. If only Webber could start a F1 car as good as other drivers, the start hurts his entire race. Imagine he started well like all other drivers from his quali positions, would be a much better first lap out as being mid-pack has so much risk with being taken out!
maybe they are giving mark a few extra chances because it is going to be his last year for 2 reasons. 1: if they can send him out as WDC would be nice. 2: if it makes it look like they don't favour vettool so much then when mark leaves they might get some better drivers willing to come to the team thinking their might not be so much favourtism. but once there they will revert back to last years setup where bieber gets first and second preference.
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
