  • Replies 5.5k
Posted Images
Kubica undergoes surgery to damaged elbow
Robert Kubica has undergone surgery in order to improve the mobility of his arm following his accident last year.
The Pole, who continues recovering from the horrific crash he was involved in during a rally at the start of last year, had surgery at the Pederzoli hospital at the end of last month, when parts of his elbow were replaced with two prosthesis.
According to the doctor in charge of the operation, that will allow Kubica to fully handle the steering wheel of a car.
The doctor also said that the Polish driver had been carrying out tests in a simulator prior to the operation.
"This way the driver will be able to fully handle the steering wheel, while before he was unable to rotate the palm down, so he was forced to release the steering wheel in order to turn left," head surgeon Ruggero Testoni was quoted as saying by Italian media.
"The surgery was preceded by a series of tests in a car simulator. It will take at least one month in order to stabilize."
http://www.autosport.com/news/report.php/id/100151
Haha where do you find these Formula 1 memes?
And what happened to all the Hamilton ones when he had his gay photos for his singing career or whatever the hell that was? Was expecting many laughs
dick around on the net long enough and you can find anything
What's everyone's thoughts on Aussie Dan, if he continues to perform the way he is he possibly won't have a seat next year
oh wellz
bring on the next one
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
