he was only off the track because Hamilton forced him off...
if you squeeze someone that hard, you have to realise it comes with a risk of collision.
The whole situation was caused by Hamilton, who had no chance of hanging on to that position anyway.
Exactly.
Hamo's arrogance kicked in as usual - and Pasta did what he does best.
Hamo was going to be overtaken anyway, he knew this - so just give up, take the loss of position and don't miss out on any points.
His post-race kinda summed that up the way he avoided the question "i dont remember". cops arse he didn't. He remembered exactly and new he had a part to play regardless of who was "as fault" as determined by the stewards
  • Replies 5.5k
Posted Images
No way.
Hamilton was brilliant there (I hate hammy). Shoved him off the track leaving zero room. You either yield and slot back in to overtake elsewhere or crash. Most drivers have the common sense not to crash... He only had 1.5ish laps to go? Sorry but if I was in Hamilton's shoes I would've done the same and defended like crazy.
don't the 2012 regs read that you must leave a car width available? Hamilton drove Maldenardo off the track, and Maldenardo hit him. IMO they both should get a penalty
I think the rule is along the lines of they are only allowed to move once to cover an attack, they cannot repeatadly attempt or something.
It was raised in i think Shanghai or KL
he can run him out of room on the exit, under braking is where the new rules stop people like schumacher chopping you off the track
Hamo did the right thing and pushed Pastor wide as he had the racing line, Pastor refused to accept the failed attempt and brain faded for a fourth time now, taking out Hamo and himself by hitting him in the rear of the coke bottle
What hamo was doing by keeping him behind is what called racing, what pastor did is called gp2
Pastor kept his foot in it, while off track, and had nowhere to rejoin BUT into the side of his opponents car. Total and utter balls up. Yet again
Is he far enough up the side for Hamo to leave him a car width? It kinda looks like he was.
If Maldonado didn't back out at the apex of the first turn then it was always going to end in tears when Hamo turned into the apex of the next corner.
the rules actually say "deliberate crowding of a car beyond the edge of the track is not permitted"
very harsh to penalise Maldonardo IMO. Penalise both or neither.
Edited by hrd-hr30
what was truly appalling was how Senna was penalised for the contact with KK
Agreed, was quite surprised to see him get a drive through for being driven into.
How did you feel about the defending that Rosberg did a few races ago (can't remember which track :blush: ) on the straight?
Hamilton had the racing line...Maldonado was never going to make that pass around the outside into that corner, so he should have yielded and set himself up for the next few corners.
He would've passed him no worries, but he got impatient and drove straight into him instead.
As Ivan stated, it's called racing. If there was 10 laps to go Hamilton would've more than likely let him passed without a fight as he would've lost time defending a position he was never going to keep, but with a lap and a half to go, any race worth their salary is going to defend hard.
/thread
i think this was covered slightly a bit back, but didnt anyone else notice the way that webber in his pre-race interview felt like he was swaying towards fezza team.
if he went number 2 there i beleive he would be taking a step backwards. number 1 driver or bust........
Better find himself 3 WDC titles...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
