  • Replies 5.5k
Posted Images
What the hell were RBR thinking? :verymad::domokun: :domokun: :domokun:
Webz had Nando covered....the dires were very conservative this weekend and were never going to fall off the cliff :(
On a side note ... Sally from Home and Away has aged damn well. She used to live in the same complex as a mate when we were young...wish they were still neighbours :)
Have you seen her in action?
The reason given for the late tyre change was that the diff fault was causing excessive rear tyre wear. But it sounds a bit like a premature call given how well the tyres were holding up generally. Anyway, blaming Mark is a bit unreasonable, his start was brilliant and he went well otherwise.
is this the start of pegging back mark and letting vetool ahead of the points between them? call me sceptical but the would never let mark finish ahead in the points by the end of the year
Sorry to ruin yet another RBR Webber conspiracy theory with facts, but Webber's last 3 laps before that pit stop were getting consistently slower and the last was 2.2 slower than 3 laps earlier. I don't think they had any choice. They also 3 stopped Vettel 3 laps later and his lap times hadn't even started declining.
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
