  • Replies 5.5k
Posted Images
perhaps they didn't consider people to be so lacking in ethics as to exploit them in that fashion
hence demonstrates the wide difference between obeying the law and the 'spirit' of the law (or rules, as the case may be)
if their gaming of the system last weekend gets Nando across the line for a drivers title this one, then the end, rightly or wrongly, will justify the means
and Ferrari will plaster Alonso's face up in every dealership and milk that marketing leverage like a muthabucker...
regardless of who wins, it was a great season
shame kimi and lewis didnt have a touch more luck to add the pressure on vettel and nando in the closing stages of the year
Has been good. Damned good.
I know every driver has things go wrong every season, but it really seems to me Lewis has had far more than his share of mechanical problems/take-downs this year.
By rights he should be right there with Sebvet and Gonzo as a WDC contender in the final race, if not with a bit of a lead even :(
C'est la vie
Well Coca-Cola have been trying to acquire Monster to boost their market share in energy drinks. There have been some talks between Mercedes and Coca-Cola the past 6 months and some that think that Coco-Cola be it with an acquired Monster or other brand may step up with some major branding/funding for Mercedes. Some have suggested it could be one of the reasons for Hamo jumping on board as it gives him a profile and brand to be associated with outside of motorsport
can't find. :(
http://torcache.net/torrent/93FDA2A64B889F447705E2A223E0CCDF51A1D512.torrent?title=[kat.ph]formula.1.2012.r19.united.states.grand.prix.race
Here's the torrent, I'm assuming you already have BitTorrent or similar.
If not: http://www.bittorrent.com/
It's two gig, but has the race, plus all the pre and post race bs.
Edited by Berk
What happened to Schuey?
Pretty much circulated going backwards all race with nary a whimper barring his chop on Button. The slippery track should have suited him. Is Mercedes the new Toyota?
They've sucked since Silverstone where the tyre variability dissapeared. The car is far too hard on its rear tyres, just like it has been for the previous 2 years. The fall apart tyres we had at the start of the season actually suited Mercedes because the tyres didn't last for anyone.
But a slippery dry track is very different to a wet track - track temp is still up, as is abrasion, so tyre wear is still there. Perhaps even more so than normal because turning the tyres out of the slow corners on the slippy track will hurt them more than normal. In qualy tyre wear doesn't come into it and Schuey once again hustled the car into a position it had no business being, just like he's done in the wet all season. But in the race, the tyres just got torn up. They were the only ones who had to stop twice. Conserving tyres has never been one of Schuey's strengths either, so it hurt him more than Rosberg.
Edited by hrd-hr30
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
