After a long search I finaly got my Stagea. Been to nearly every dealer in Sydney and some private ones interstate (and spent a lot on car inspections fees). Some good and a lot bad, so without further ado here she is. Crappy mobile phone pics unfortunately.
Things to do are get the radio to pick up Aust channels, reversing camera and after a month or so get the turbo built up. Shes needs a good detail and I´ll do an oil change in a few weeks.
Edited by Aegats
https://www.sau.com.au/forums/topic/384406-finaly-got-my-stagea/
Congrats on the new wheels.
Don't mind the M35s. I'd have one if they came in manual. But alas, they do nos, so I'll make do with the 34 :)
NEEDS MOAR LOW!! :nyaanyaa:
Looks nice, good luck with it! I actually saw one very similar driving through town today. Looked awesome in white, hadn't seen a white Axis before then.
So future mods...
- get the radio to pick up Aust channels - Guessing you have a Bose, so just get a band expander for it unless theres an issue with it. Then when it breaks down, you can replace it with a G35 fascia which will give you a standard 2 DIN hole.
- reversing camera - slippylotion posted up a guide a month or so ago using an ebay special camera. I take it you've got the screen? Just do a search, you'll find it, pretty easy and the cameras are only ~$30-40 on ebay.
- get the turbo built up - Why so soon? Can of worms is open!
Definelty needs MOAR low.
Wasn't a fan of the whites in the rs,rx models but the axis in white looks better than the other models.
I'm not sure what stereo as l'm already at work and didn't check. Hopefully just a quick fix.
For the reversing camera trying to get that done ASAP . I can't seem to get access to slippylotions post but trying to sort something out.
With the turbo ive been told they start to let go around 100k mark so I have some time to save for a new one.
Scotty has found it's oil feed (or lack thereof) that kills them. If they're poorly maintained the banjo to the turbo blocks and starves the turbo of oil.
Just drill it out to 2mm and you should be right.
And I am a fan of the RS in white... thats what I've got! :thumbsup:
There is really no point in taking pics, you can barely see up there and without knowing where the pic was taken from it wont help much.
You can see the oil line if you take off the undertray and look up from the passenger side. Just in front of the driveshaft there is a metal 8mm line with a banjo into the block, remove this and drill out to 1.5mm, then clean any swarf and gunk from the hole before refitting. Is your turbo noisy? Some stockies sound like a jet taking off.
Really? I think the pearl white looks hot in the rs/rx...
admittedly I'm not a huge fan of the AXIS/ARX...looks fat/bloated :P
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
