So this afternoon I will finally be picking up my 2002 250t RS four v hicas after importing it myself to NZ. I am starting this thread as I will no doubt have lots of Qs of the coming weeks.
The first of these is what do the side curtain airbags look like? I have noticed these small sorta rectangluar bits at the top of each pillar in between the front and back doors, is this the airbags or does everyone have them? Will try and post a pic if I can.
Also if anyone has any Qs about importing your own motor to Nz then I'd be happy to help
https://www.sau.com.au/forums/topic/384887-new-m35-owner/
If they are airbags shouldn't they have "SRS" inscribed on them?
AFAIK it was a factory option and not many cars came with them...
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6139366
Lol I'm sure mine will b fine unless the mrs is driving it, having said that I did write her car off rather spectacularly a few years back, airbags taste quite stingy from what I remember! Other driver ended up in cuffs though so it was definitely not my fault.
I've just been to see my Stag, not getting it until tomorrow now as it failed compliance. Only needs one headlight level adjusting though so it's all good. The place phoned me and opened with" its gonna need some repairs", my wallet winced til he told me what it was lol,
First time I ever sat in one was today, impressed so far and really pleased as I've saved a fortune importing myself.
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6139716
OK thanks for your help so far guys, the compliance place fixed whatever was up with the headlight for 30 bucks so its all good. Today I actually got to drive the car instead of looking at pictures everyday like she's some dirty girl off the internets :wub:.
First impressions; so smooth, so very smooth and quiet. But then it turns into a beast once the turbo winds up, the grip is just at silly levels. It feels a bit floaty on occasion but I guess that's coz I'm used to driving on hard suspension set-ups?
My Turbo is quieter than I expected, you can hear it but its definitely not loud like I've read many others report but I guess this is a good thing? It does come with full Nissan service history so I'm hoping I'll get some more life out of it yet.
One question, the button that locks all the doors located by the drivers elec window controls does not lock the drivers door is this normal?
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6141589
$30 - can't have been much of a problem :thumbsup: .
I thought grip was great on mine too. Then I started modifying & it gets heaps better.
You may get years more out of your turbo if you look after it with quality oil & reasonable change intervals. Or you may not.... hard to tell really.
Yes, the door lock is functioning correctly.
Can you post some pics? It's always nice to check out the new guys ride. And welcome to the Stagea forums. We are generally a decent bunch around here.
Edited by Commsman
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6141638
Well I did my first service today, used some Castrol Edge 0w40 and a Ryco oil filter. Also put a new air filter in there. That tray on the bottom on the engine is a bore to get off but once that's done the sump and filter are easy to access which is good. Air filter took me bloody ages to figure out that you just need to give the airbox a good yank and it comes right out haha. Also had a good poke under the car, no nasty surprises so I'm pleased.
I def do NOT have the side airbags.
Quick n00b question about tyre pressures, should the back be higher presure than the front or the other way around? Have the sticker telling me the pressues but its in jap of course
Have given her a bit of a :spank:and have to say LSD = win; lots of fun. They don't half shift for a big car.
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6147331
40psi all round :)
I used to run 40, thinking it was on the high end, then more than one tire place told me that was too low. They suggest closer to 50psi as I'll scrub the edges off anyway so might as well wear the middle of the tread with the higher pressure. Ask around as I'm keen to know if it's just a local thing or if it's a widely held belief. BTW, may not be as applicable for different sized tires. Mine are the popular M35 size, 245/50/18.
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6147457
Huh????why?
"please explain"
Best combination between comfort, economy, tyre wear rate and handling.
Any lower and it felt soggy and I found a noticeable decrease in economy.
You go lower or higher?
Reasoning?
EDIT: I should mention that was with 225/55/17's although I did run the same pressure when I had the Nismo's (234/40/18).
Edited by iamhe77
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6147482
Reasoning?
I run in between 34 and 36 on the street for extra grip unless I want to have some fun in the wet!.....Aussie roads are shit so 40PSI would no be a nice ride and imo you get no handling improvement. I always look at tyre pressures as another suspension adjustment.
running 55 series tyre though I can sort of see why you went up in pressures depending on your tyres. E.G. Nankangs felt mushy on the sidewall even at 40+ psi on the track...the Falkens I have only ever gone to 38-40 PSI on the track with bleed off!
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6147611
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
