  • 3 weeks later...
Brad I'm still waiting for my surge tank that i paid for in May, you have told me that you have sent it on numerous times over the past couple of Months, and that I would get the tracking number the next day, i have given you more than a fair chance, i even had orgnaised a close friend that was in sydney on a Saturday to meet you to pick up my surge tank, you didnt answer your calls like you said you would. How would you like it if i had you complete work and not pay for months on end! You had no problems taking my money. Contact me. if anyone can get a hold of Brad can you get in touch with me.
My car is there now and is almost finished. Job got a lot bigger than first agreed and naturally timeframes extended by a few weeks which was totally expected.
The service I have received is sensational and the work on the car from both Brad and Dylan I could not be happier with.
Will post some pics of the work shortly.
  • Like 1
The work is obviously good, but seriously ripping off customers for his own gain is terrible! This needs to be addressed!
It would be interesting to see the amount of money that's been thrown at this guy.
That's fair enough... But that only shows that he is dismissing all the other problems in gain of trying to get new customers!
He has lied to so many customers using his wife & his very young daughter as a tool to get out of it all, which personally is the weakest form possible!
I have lost respect for this guy & I'm sure many others will agree with me!
  • Like 1
This. Well said.
I am now calling this guy multiple times a day. I have had absolutely no response. And if the outstanding parts and money aren't enough he still hasn't returned the key for my car. There is no spare.
If anyone would like a secondary phone number for Brad, PM me.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
