I'm not closing, there is far too much work to close.
Just moving stuff around and limiting the usable area for a while. Hence trying to wind down orders so I can focus on the 4 complete car builds while everything happens.
Recent work has involved fitting a couple of 6 speed holingers and custom mounts for GTR's
This would be the 5th or 6th holinger that ive fitted recently. They dont get any lighter or any easier to make crossmembers for though.
New alloy door trims for FATZ R32 GTR.
Ive folded up some neat mounts for the original window switches and folded the sheet to accomodate the shape of the door as opposed to just screwing it on and letting the sheet warp to the shape which can look terrible.
A fabricated power steering resiviour. These have become fairly popular lately.
Surge tank that was welded up this week
Next cage job in the line up. The WTAC winning EVO of Nik Kallis. In for a new 4130 molly cage and some lighter weight components
Cages next week for dash sport and insight motorsport as well.
Im releasing a new product next week as well.
The first ones have now been fabricated and fitted with excellent feedback.
Offereing a new sealed & vented light weight alloy battery box.
They have a hinged, securable lid with a substanciable base plate to bolt down to the vehicle. Cable glads to seal around the battery cable and prevent chaffing. Built in battery retaining clamps.
Perfect for guys looking for something thats more appealing than the old school plastic battery box that still vents into the cabin and looks rather ugly in the boot next to their fuel system or dry sump setup.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
