Thought id do some welsh plugs today, got the water gallery ones, they were in stock at the local Rip Every Poor Cnut Off store, but had to order in the 22mm oil gallery plugs so waiting on them for friday i hope. Gave the thing a new lick of paint too.
Fresh paint, its like a Dulux overhaul :P
And the mains offered up and torqued down prior to me measuring the tunnel, It is slowly starting to come together!!
Just to change it up a bit, i got creative with the spray can today and grabbed the inlet manifold, cam covers and coil cover and gave them a lick of paint too. Good old wrinkle paint in black, never fails to look good.
Here i was gapping rings, probably the most boring excercise known to man, besides shopping with the missus...
Thats about where im at at the moment, just waiting on brad at spool to send me a crankshaft and some conrods and ill be ready to start dummying and checking clearances on bearings, endplay, crankshaft straightness ect. Hopefully i will have the head back in the first few weeks of january and then its on the blower to PFRE for some under car surge tank and extended sump fabrication and i can start doing the final assembly :)
Hopefully! I was looking into a power figure i want to reach, but it is getting scary with the mods and sods that are adding up. I was going to try for a tough streeter with the ability to go at the goat track we call Benaraby Raceway. Seriously thought about flogging off the T78 i have in my possesion and go for a Journal Bearing Precision turbo, but im still undecided as i have had the fun linear delivery of lowmount twins and now i want the "Kick to the nuts" delivery of a big healthy single to keep me interested in the car. Well, interested enough to keep perservering with it.
Cheers, Allan
Well, got my power figure i want to reach. Mid 400 killerwasps on low, and i want to crack 500 killerwasps on high, Pump 98, thats all we have up here. I have been trying to find if the trust t78-33d's are capable of that, but havnt been able to find alot of info on it. Most of the results ive seen are all on E85 :(
I have just put a ball bearing Precision 6262 on my car and have not regretted it one bit. Strong low down response and torque on a bog stock 2.6 so a built 2.8 would be rediculous. You should go the slightly bigger 6265 i think it is to get the mid 400's
Awesome car man, it's going to be great when it's done.
But how did being a mechanic all those years ago teach you how to build something specific like a worked stroker rb26? :huh:
Also, how did you get this effect? Did you have to bake the paint or did you just hit it with a wrinkle paint straight from the can?
Well, i got the crank in, bearings all guaged up, and come up primo :) crank run out is spot on and the crank is straight as :) Measured at #4 main journal it was 0.005mm :) very happy with that result. The finish of the crankshaft is also good, i went over it with a fine tooth comb and couldnt fault it, bar the one niggling little thing, the oil pump drive. Its not machined into the crankshaft, its a collar on this crankshaft, but i can live with that. Also got out the scales and weighed the rods and dressed pistons, all which came up to within half a gram of each other so im also pleased about that. Now im off to dig out my internals and measure the conrod bush to pin clearances and the big end clearances :) If all comes up to within spec its time to clean and assemble the bottom end! Pictures will follow tomorrow morning when i wake up and get over the incoming hang over lol
i did round the.port.divider slightly kungpiw. i only ported the exhaust side after some online research revealed to me that the intake port design of these cylinder heads is actually quiet good. all i did was smooth out some imperfections and blend some small areas. for those interested, i weighed the two cranks and the standard crank come up at 20.21kg versus the stroker crank at 24.41kg
So....just hit a MAJOR snag. I was called by the machine shop and told to come and pick up my cylinder head. It was a pretty rude and abrupt phone call so i was worried, and with good reason. I got there and he went out the back, brought it all back in, in boxes and said "Our machinist has quit, we dont know where he was up to, he hasnt given us an installed height and we wont be completing this job, you owe us 585 dollars, pay it now or we will withold all of your items." I was not too impressed, so i have a head, half complete, half assed and nobody in this part of the world wants to go near it. I am pretty shattered. Anyone know anyone with a half decent turnaround time that would take on the job? It looks like it needs to have the installed hieght matched, needs reassembling(springs, retainers, stem seals, shims and buckets) and needs the cam clearances set. I'd do this but i dont have the equiptment to top the valves and do the height, and the shop usually assembles it as part of the deal anyway. Any help is appreciated
Cheers, Allan
I have an rb in at Jacobsens engineering shop here in bundaberg, which one were you using?
They have done great work on the 803rwhp supra we built, accuracy was excellent and they did exactly as I asked and price was reasonable too.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
