Nothing too major. Just a quick job. Should be hopefully all plumbed up tomorrow, then i need to chase down a dual feed rail and the fues system is done. On a side note, Open bar at the christmas party tomorrow night means im gonna get pretty fcuked up lol
Got the surge mostly in today. Just need to track down some 3/8 return lines and its done! Also got me a new Rock Stopper :) Pics below
Power steer tank
Surge tank nearly completed
Really needs a larger filter lol
  • 2 months later...
slowly roy. Had a fair few time constraints lately, had averaged over 90hrs a week up untill Christmas. Just waiting on a possible fuel rail group buy i will be doing then im set to go i think. Getting pretty anxious and really want it done to be honest with you lol
Is this an off the shelf item? I'm interested in one of those and the pwrsteer reservoir.
I fabricate both of those components in house.
The surge tank is a generic fitment for R33/34 & V35 skylines. I don't keep them on the shelf but fabrication time at the moment is fairly reasonable.
The power steering resivour is fairly trick and shaped to the wheel arch. That is R33 specific and won't fit anything else so I don't keep them in stock either but again fab time is fairly prompt currently.
  • 2 months later...
Recieved a hypertune rain and a turbosmart reg today. Ran into a small issue with the outlet direction on the P/S tank, just need to change the direction of one of the barbed fittings so i can fit in a bov return pipe through the same hole as standard. Just waiting on a few speedflow fittings, some 90 deg barbs and some injector extensions and then its good to go for a run in tune and some bewst
  • 2 months later...
Got some Jew brew and started it last night. Turns out I have a damaged turbocharger. Has a thrust issue as the front compressor is fouling on the backing plate by the sounds. Also has a faint knock when slowly spun.
  • 3 weeks later...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
