Very nice! Freshening up the L24, or just going to see how it goes?
Im just going to clean the motor with new welsh plugs, water pump, thermosat, exhaust studs and a few gaskets. i just want to get the car on road with the L24 then see
how things go from there.
Still looking for a pedal box and gearbox. So if we can get some fine weather, i can fit all these parts to the motor and fit it as soon as i have a gearbox :cheers:
Couple of things learnt today, first and most important is always ask before buying lol. And here are the rest.
240k and 240z do not have the same door handles.
Ebay photos looked close
But different shape and size
C110 and C210 do not have the same door locks.
Look the same from the front
But from behind the they are different, i tried changing the backs over but they are different too.
Installing this required more skin then i liked lol
Also 240z pedal boxs are not the same as as 240k, but the 260c looked about right but was not able to strip this car of it.
Hmmm so i got some nice pics today before the rain,
Also a good day to fit the windows(could not get a new rear window)
And fit the new badge
This has made me want to finish the car even more so updates should come a little quick for 2 weeks or so.
  • 1 month later...
I have thoroughly enjoyed reading through your build thread. Can I ask, apart from Ottomoto, where else have you sourced all your parts/stickers from? I'm currently building one and any help would be appreciated.
I am in Sydney as well so maybe when mines done we can go on an old school GTR cruise!
Alot of my parts are from Yahoo Japan and other sellers like Rubber-soul and cityauto which are japanese sites.
If looking on Yahoo go throught importmonster so its all translated for you, Here is what you sheach for ケンメリ
There are 3-4 of us(all building GTR clones) that share info,sites and good buys we find. Also try help out with spares and what not we have picked up.
  • 3 months later...
Hmmm many months not a great deal to up date. Still waiting to get my SS trim back over 6 weeks late.
I got these parts today so need to have the flywheel machined then i mite get this motor back in. Be good to get back into this car again. Also have JDM lights on the way too.
    • It's sodium citrate, I misspoke earlier. It's a citrate buffer solution. And yes, depending on how thin the metal in the tank is this may or may not be a wise decision but if it's just mild rust it should clean off and it should be fine.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
