OK, have some parts for sale, prices are negotiable - to a point. I know what they are worth, so if youre going to lowball, dont bother.
Nismo ECU (might be sold with car instead) $1500
Emanage Ultimate with Boost sensor and wideband plug $450
G35 Aluminium radiator (brand new) modded for M35 with auto trans loop $300
Greddy EBC (brand new) $350
scotty dump (brand new) $400
Kakimoto de-cat front pipe (fantastic condition - will make a good combination with scottys dump pipe) $450
Rear section of Apexi N1 exhaust $250
All parts are located in Eastwood, NSW and are for pickup only.
Edited by zei20l
https://www.sau.com.au/forums/topic/386248-m35-aftermarket-parts/
  • Replies 50
Posted Images
PM sent.
the radiator is pretty much sold
however its a 56mm core all aluminium V35 radiator modded mounts and cap point so it will fit an M35.
its wider and thicker and will hold more volume
ok the N1 exhaust rear-section looks similar to this:
Yes its only HALF of the cat-back. it wont bolt to the factory exhaust, and it needs a mid section made up.
Everyone knows what a scotty dump pipe looks like, Ill take a pic of the kakimoto front pipe on the weekend.
However, it runs from the back of the dump pipe to where the cat-back exhaust would bolt on, also taking the position of the cat. thus a de-cat pipe.
hope that helps everyone!
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
