I see a bit of surface rust, but the detail isnt much better that i can see mate. Description may help us :) Id be getting some very fine wet and dry and trying to polish that rust off too, provided its not too deep.
All I can say is:
800 grit
Then
1000 grit
Then
1500 Grit.
Then install, and realize they they don't fit and need all sorts of shit changed because of the massive lift.
Also, if they do work, then I'm assuming you have an engine that will rev to 9,000rpm to 10,000rpm because those cams will only be good from about 5,000rpm upwards.
Still surprised at people that think bigger is always better when it comes to cams.
you can get them micropolished by a machine shop and they should be fine. I wouldnt risk the sandpaper method on a good set of cams.
i cbf for a keyboard war but there is no simple rule of thumb for cams, the 10,000rpm comment is not accurate. keep on topic.
Piss off Mafia, the thread didn't ask 'are these cams suitable for my build which you know nothing about', did it??
Thanks Allan - still feel smooth to touch, appears to be some discolouration from sitting unused for a period of time. Mainly seeking feedback if people have seen this sort of thing deteriorate rapidly or if it's purely cosmetic. Now I've shown the previous owner he says they've been run as pictured in his race engine with no issues which is somewhat reassuring.
Edit - thanks Scott, I'll speak to the head shop about micropolishing.
Edited by DCIEVE
Most shops stick them on a slow lathe and use sand paper anyway.
Last thread about the size of cams were mentioned, the guy had no clue and didn't realize that 270s were going to be unsuitable for a standard engine and mid sized turbo limited to 7k. he thanked us and went a pair closer to 256 or 260.
But I have no idea who you are or what you're building so if you're going to be like that then you can jam it right up your ass. Sideways.
P.s. I wet and dried my poncams and they came up like new. Never had an issue.
Just be sure they dont have to polish them too far. Thats why i always try a bit of 100 or 1500 wet and dry first. If it comes off easy then keep at it, if its deep and isnt going to budge, send them in to the machine shop. They may even say to grind them back, metal spray them and have them re-ground to original spec's so just be prepared. If you are going to try the wet and dry polish at home remember to not go too hard on it, just light and easy and remember to not concentrate on any one sopt for too long.
Good luck and get beer :)
Cheers, Allan
Maf was trying to stop you potentially wasting your time and/or money, because a lot of guys go for cams that are too big. If you're confident with your sizing, you could say "no worries, I've done my homework with cam sizing" and leave it at that.
I'd use fine paper wet with engine oil if you're going to paper them. I used 1200 grit wet with brake fluid on my brake pistons - came up nicely and worked well in service. Sandpaper should be low very low risk if you go slowly with a fine paper and check the surface regularly.
As I said, I had no idea what you were building or who you are.
9\10 threads about cams, the op has no idea.
The fact that you came asking about something as simple as surface rust lead me to believe that you may have been a rookie that was looking at some cheap cams from jimmy around the corner.
Put it all together and it looks as it looks. I was trying to help out a potential rookie.
But, you came out with your chest puffed out and lots of dickhead attitude instead of correcting me.
Anyway, good luck with your surface rust.
Mate fact is if you say the "surface rust spots" cant be felt with your finger dont worry about it.... The important thing/part to look at is right on the crest (top) of the lobe...U dont want pits there at all.. Ive used 282deg 11.0m lift cams on a few engines and all being done/setup correctly theyre not that bad.
Dude u pulled my stock cams out if my engine in the same if not worse condition in terms of surface rust...
Engine ran fine with them, not sayin it's a good thing at all and I would defiantly clean them up...
How the he'll does this happen by the way? Surely they dont go in clean and come out with surface rust!
surface rust / heat stains, though they do look a little porus (as in metal sprayed then ground to a large size, not ground from a billet, cheaper to manufacture) but thats all i can get from a picture
but i wouldnt stress about them not looking pretty if you cant feel it
at minimum id recommend a Linish as micro-polishing is a completely different process which takes about a week (but if you got the coin id recommend to get them micro-polished)
this is coming to you as first hand information from someone who is qualified in the engine machining industry
(and go easy on mafia he knows his stuff)
linishing
http://image.turboma...haft+polish.jpg
micro-polishing
http://media.photobu...d/esp_armor.jpg
I think linishing can impact tolerances though, whereas I'm of the belief micropolishing wont harm the specs of the bearing section
I'm happy to be corrected there though. I just see it more of a mission to linish then tunnel bore (if needed) than paying a little extra to micropolish. I think phone calls would need to be made before going any further either way, pitting is never good for soft metal bearing sections (IE cast sticks into an alloy head or cast crank into copper bearings).
I did happily use a pitted flywheel recently though (with a brass clutch) lol
BTW, they look like they have a small base circle, maybe 29,30mm so you'll need special buckets or really thick shims. Cheers n good luck
Yes correct, this head & cams have been run on another SAU members race engine and are simply being rebuilt before going on a new short motor. The machinist is shut for Chistmas so I thought I'd get a second opinion.
I had/have no interest in being baited into an e-battle about cam selection so the alternative was telling you to take your advice elsewhere. I would apologise for not being delicate enough but your the one throwing the insults.
As suggested - rub them lightly with wet and dry sandpaper. If, after that, your fingernail gets caught on any pitting or imperfections, they will be no good for use in any reliable form.
As for camshaft sizes, 270 x 11.4 is nothing. Lift is critical for maximum torque gain. Duration is what will effect the RPM range of its efficiency. And even then, are they 270 at 0.020 or 270 at 0.050? What is the ramp duration? If no one knows the answer to that then speculating what they will and won't do is a silly idea.
So effectively all lift does is get more air in/out because the valve opens more but still opens and closes at the same time.... Correct?
Where as a larger duration will extend the time in which a valve is open and there for move the power to a different point in the band... Correct?
Also duration is calculated by the amount of engine degrees that the inlet or the exhaust is open for while LSA lobe separation angle is the amont of overlap of the inlet and exhaust...correct?
These are half startment half question replys btw :)
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
