Hi all,
I'm about to throw a set of 2860's on my GTR and was wondering if anyone could fill me in on what size of oil restrictor they used? Mine are a second hand set and it looks like they don't come with in-built restrictors.
Should I use a restricted banjo bolt to the engine, or should I run a small restrictor in each turbo?? I know some peeps have been running in-line 0.035" restrictors..
Any input would be greatly appreciated!
Thanks
https://www.sau.com.au/forums/topic/386688-gt2860-oil-restrictor/
Only after market lines use a restrictor at the turbo when you are feeding it with a -4 size hose from a main oil gallery. The size restrictor you need for after market lines can be found on www.atpturbo.com.
If you use the factory oil lines, there is no need for an extra restrictor. Where the oil comes from the block, the banjo fitting that goes into the block has an internal restrictor. I think it is labeled with an "M" on it. The factory lines are better quality than anything else on the market anyway.
If your coolant and oil lines are looking a little shoddy, take them to a brake line place and have them nickel plated. They will look like new then, and you will also get addicted to plating everything that unscrews from your engine bay!
correct me if im wrong but the 32 and 33gtr never had built in oil restrictors as their turbos were never BB from factory unlike the 34 gtr.
i used a 0.8mm restrictor on my banjo bolts for the oil line on the turbo whcih i got from kando dyanmic on ebay.
I'll save you the search.... all standard and vspec R32/r33/r34 gtr turbo's are ball bearing and ceramic turbine wheeled. N1 options are steel wheel, and ball bearing. All require restrictors.
Even bush bearing turbo's require restrictors. If you run any turbo without a restrictor, expect to see oil in your intake and exhaust as the oil can't escape down the drain quickly enough. Only with very big drains will you not get an over-flow issue, but its still not the right way to do it.
The Trust T517z's bush bearing 8cm and 10cm kits for example come with restrictors in the banjo fittings that go into the turbo's. They are a different size to the factory restrictor.
:huh:http://homepage.ntlworld.com/tbroom/Turbos.htm
HKS supply additional restrictors in the banjo bolts on there gtss and gtrs turbos kits
GCG have told me that on the 2860's they have built in restrictors
Back when I used to listen to what people told me... I had heard that statement many times before as well.
I beleived it too, until I had first hand experience with oil in the intake and exhaust because the 3/4" oil return couldn't copy with 75psi oil pressure. Then I was advised to replace the turbo for a new one, only to continue having the problem. Nobody ever asked how the turbo was getting its oil supply, which was a -4 braided line from a main gallery on the block.
Magically my oil problems went away when I used the atp turbo restrictor at the turbo.... that everyone told me I didn't need. :teehee:
Perhaps they mean its "built in" to the banjo fittings.
While I've not seen a HKS turbo kit new out of the box, I would suspect the additional restrictors would be used for those applications where people are using a high volume pump such as the tomei or HKS pumps with the oil pressures dialed up to 100PSI or more. In those situations an additional restrictor would be needed. There is no one size fits all applications.
I can say from experience that the HKS turbo's work fine with the standard oil plumbing and restrictors provided the oil pressures are kept at the factory levels of not more than 7-8kg/cm. Im using GTRS's with factory restrictors, tomei pump(no additional shims) and 20w50 oil with no issues in my car.
Are you talking single or 2860, gt sereies etc twins?
GCG made a note that its in the core of the 2860's
ive done installs of 2860's, hks gt series and gone from hks back to 2860's
one thing that is worth noting is not using the hks banjos when going from hks to 2860's
ive yet to here of problems with any set up regaurdless of oil pump.
I've seen oil overflow/restrictor problems with single and twin 2860's.
I believe it was BoostedR with his 2860-10 equipped 500kw RB3026 R33 GTR that was also having issues getting his restrictor sizes correct. I also read about someone with a white R34 GTR that saw a fair bit of track time that was having issues stemming from sustained high RPM/high oil pressure. I am not alone in having experienced this.
Like I said, one size doesn't fit all applications. A restrictor will limit flow for a given oil pressure, but once oil pressure exceeds a certain point the restrictors must be made smaller. Same principle as the head restrictors.
I am sure that even GCG would tell you to run a restrictor if your oil pressures are reaching 100psi+ at max RPM, because the out of the box GT2860-x series turbo's are designed as a bolt on upgrade where oil pressures are that of a STANDARD engine, not a modified one.
Hi all,
Thanks
2860's do/should come with restrictors built in. Just to make sure we're talking about the same turbo, they should have a badge on them with a part number. It should have 707160 on there, and then some sort of number after that.
e.g. if its 707160-7 or 707160-5 then this is what people are referring to when they talk about -7's and -5's...
The restrictor they come with factory is a 1.2mm. There is an option to fit a 0.8mm. I fitted these since I have only 1 oil drain on an RB26/30 and also run a Tomei oil Pump.
Below is what the restrictor's look like out of the turbo. You can see the small 0.8mm hole on the side of it (which is not visible when fitted in the turbo, at least not easily)
And the pic of it fitted to the turbo shows it's top. So have a look as see if you have this in there.
So what are the down sides if not having any restricters? I have recently put in a set of -5 turbos and now the car is blowing alot of smoke from the exhaust. I'm pretty sure its the lack of oil restricters???
If you don't restrict the pressure getting there it can fill the oils drains too fast and fill right up to the exit of the turbo - at this point the 'pressure' has to go somewhere and gets past the turbo seals (usually the exahaust side). Hence tons of smoke. So its important not only to have a restrictor, but also large and free flowing drains to the sump.
  • 3 weeks later...
GTRNUR, the R32 and R33 GTR turbos are 270 and 360deg plain/journal bearing setups depending on car model as per chart in link below and require higher oil pressure. I have stockies and N1's at home and they're definitely not BB ;-)
Well, at this stage I'll be going with a set of brand new GT2860 -5 or -7 turbos that should have inbuilt restrictors just like other BB turbos from Garrett etc. However, I'll be sure to confirm with the turbo mob that they're fitted with the right dia. restrictor.
R32 TT, thanks for your info there mate! Appreciate the photos too and apologies for late reply!
That would be correct. Also, only the R34's have those banjo bolts with the M engraved on them as they are restricted for the BB units that only R34's run. I was going to maybe use one of these if needed - but hopefully the GT2860s will already have the right restrictor in them etc etc..
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
