what do you think of the rb26 miata mx5?
72 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hello a few buddies of mine started this project when I met them about 4 years ago ,a RB powered Miata mx5 !!!
at first we installed a rb25 neo motor had to do allot of r&d and we went 9.8 @ 143 in the 1/4 mile. while all that was going on we had been working on a rb26 building it from head.to toe! The car now has a RB26 fully built with a powerglide 2 speed gearbox,GM differential,custom made axles especially for this car from the DRIVE SHAFT SHOP AXLES,a pair of 26x10.5 Mickey Thompson full slicks , Garrett gt42-45R dual ballbearing turbo,c16 race fuel,26psi making over 800hp and 600+ ft.lbs.tq
let me know what you guys think!
this was our 9sec pass On the 5 speed manual gearbox (still had the rb25)
This was our first pass on the powerglide gearbox we didn't know how the car was going to react we wanted to see what it did so we could dial in the launch and everything else after
We were so happy the car did so great on the first pass!!!!! (RB26 set up )the car is capable of doing 8's , the 15th of January we are going to import face off here in SoCal we are definitely going 8's !!!!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/
  • Replies 48
Hmm thats a very interesting conversion. Its amazing how many different engines have gone into mx5s over the yrs. I personally would've gone a TT Lexus quad cam. But hey each to thier own :)
Edited by Raysboostin
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6173737
This is another video we went 10.1@91mph driver let off half a track and step on brakes at the end we were in a class for import face off we didn't wana get discualified lol Edited by nismorb25neo
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6178611
No I wish lol the motor wouldn't have let us put the radiator in ,we wanted the radiator to fit and not have to cut the crap out of the front so we cut 3" off the firewall to make it fit better,and it actually worked out very well and were very happy with the outcome! The 15th of this month is import face off here in SoCal,hopefully we can hit the 8's,were very excited about it! Its been a long journey to be where we are now alloy if sleepless nights and R%D. I will be posting up the videos for sure for you guys entertainment!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6181828
No I wish lol the motor wouldn't have let us put the radiator in ,we wanted the radiator to fit and not have to cut the crap out of the front so we cut 3" off the firewall to make it fit better,and it actually worked out very well and were very happy with the outcome! The 15th of this month is import face off here in SoCal,hopefully we can hit the 8's,were very excited about it! Its been a long journey to be where we are now allot of sleepless nights and R%D. I will be posting up the videos for sure for you guys entertainment!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6181984
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
