Hopefully this has'nt been answered, but I am about to finish all my refit of my s1 rb25 and I need to confirm about the timing belt tensioner, the spring is meant to adjust the belt correct?, so i did this and it doesnt hardly even move the belts slack... Am i meant to wind up the spring before fitting it over the stud it sits on? I set my belt with an allen key, but im worried about tension. I set it last time too tight and it was making a whirring sound, I want some reassurance/help with this because i have a near 20k motor that I dont want to **** up. Thanks
The Nissan manual says to put the engine on TDC and loosen the nut on the tensioner. Do 2 full laps of the crank and stop back on TDC. Then tighten the nut on the tensioner (use an allen key to hold it in place). I've done it this way on 3-4 cars now, and it works a treat
None of that info helps if he hasn't got the tensioner spring doing its job.
Yes you have to preload the tensioner to get the spring working, otherwise it will just sit there as you found out.
Take care you don't get any windings gaught under the tensioner where it mounts to the block, that will cock it over and run the belt off.
Next as it's a Gates belt, my opinion is that the workshop manual info won't work, the belt gets too tight once things reach operating temp.
From experience Gates belts have to be setup looser than the factory belt, which is why no more Gates belts for me.
You need to be doing belts daily to have the "feel" for Gates belts.
I did mine by relaxing the tensioner and turning the harmonic balancer a few revolutions. The tensioner will than move into the correct spot and all you have to do is keep pressure on the belt and tighten the tensioner up. Hope that helps ( I was told this by 3 different mechanics so hopefully its right as i had over tensioned mine as well the first time ) Had no problems what so ever
jiffo's right, I know how to rotate to set and all but my spring itself isnt right, it holds all but zero tension on the belt. Its not damaged just not coiled up....
So when it used to whir with my first build, it was obviously too tight, so can it be all but whirring? I realise what a loose belt ends up doing, but what does a slightly too tight one do?
Thanks for the input though guys
Mate does it have the stud in the block that the spring rests on to put tension on the spring? If yes then your probably just not locating the straight part of the spring correctly. A belt thats too tight causes a few problems but most noticeable (what i see on engines that have been built by others that ran belt tight) is excessive wear on the 2 very front cam bearing tunnels, the one which holds the seals, its always on the inner side as the belt is trying to pull the cams towards each other. Belts also tend to go shiny when too tight. I usually run about 4 deg play. ie: wind the engine over by hand (breaker bar) until you pass a compression stroke (doesnt matter which cylinder) but you'll feel belt looses drag. rock the crank back n forward n you should have about 4 deg play...Hope that doesnt confuse you too much but its not that difficult. Just take your time ;-)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
