everyone is telling me to get a nistune done on my 33, i know that its a computer upgrade to your standard ecu, and it unlocks more potential. what potential is that? do i need to change engine components or will it run on a stock standard engine? and most importantly is it a plug and play or do i need to take the car to a dyno to have it tuned like i would for an aftermarket ecu? any info would help. oh and how much does it cost to get done?
https://www.sau.com.au/forums/topic/388422-how-does-nistune-work/
It's a piggyback board that is put onto your standard ecu, It's fully tunable and yes you will need to go to a dyno to get it done. Most places will charge around the $600 for an initial tune. Yes it will run on a stock standard engine.
cheers thanks for that.
My question is, why do you feel you need to change to a programmable computer? Are chasing more power?
But yes, NIStune all the way as far as i'm concerned if you dont need all the extra features of an ECU such as a Haltech, Link, Microtech, Megasquirt etc.
WARNING.
You cannot put a Nistune board into your R33 ECU. If you want to Nistune your car, you will need to get either an R32 ECU or a Z32 ECU and do that. There are differences between them. The R32 does not control your inlet cam. You will need to get a window switch of some sort to re-enable VTC on the inlet cam if you use one. The Z32 ECU, on the other hand, does control VTC, so makes that easier, but there are some other hassles with using a Z32 ECU on a 25. Your best bet is to google and read up the very many threads on this and other forums on these topics.
The main reason to put Nistune onto an R33 is to allow you to turn the boost up to 12psi (about the limit for standard turbo) and then tune out all the extra fuel that the standard tune puts in at that sort of inlet flow, and also to wind some timing back into it. The stock tune is horribly conservative. You will make more power and use less fuel.
Oh, the other reason to go Nistune over any other programmable ECU option is that to pretty much any cop it looks just like a factory ECU and they would actually have to open the ECU up and look inside to see that it has been modified. Pretty close to the only defect free ECU option available.
WARNING.
that was exremely usefull thank u. ya i am chasing more power, but from what ive been told my standard ecu is shitting itself. im replacing the engine as the engine has lost compression, and my friend is buying it off me. the problem then lies that if i put a new engine in, the ecu is going to give me shit. its overfueling on standard boost and at 12psi, im regestering all 12psi so there is no boost leak but it feels like im not hitting boost at all, it drives normally, no noises or missfires. but put on a dyno it has 140rwhp. so ive lost about 60-80hp somewhere. i thought it was compression (140psi wet) pritty much even. i know its low but everyone said i still shouldnt lose that much power, as well some one on here told me that the factory computer is set to over fuel itself when dickheads just up the boost without considering the AFR. and aparantly they tend to shit themselves or that specific part of the fuel map. i dont really know im still trying to learn.
Yeh most plug in ECUs can use the stock cover these days. Can do the same with VIPEC, adaptronic etc.
I wouldn't go NIStune with an R33. Personal opinion. As has been said, go read some of the threads about all your choices, there's a gold mine of info here.
  • 3 weeks later...
What do you guys consider an acceptable quote from a business to supply the nistune chip, mod a z32 ecu to support the nistune and then install and tune for an r33 gtst?
Im guessing i would have to supply the z32 ecu so exclude that from the cost...
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
