  • Replies 45
Yeah I wouldn't do a clutch myself, I've spoken to a few places and got a quote for $1206 for a stock replacement clutch and labor. Not looking good
Lol, I could probably do it for half that, but doesn't come with warranty (I'm not a workshop).
I just done a gearbox in my car this week. I wouldn't say it's that difficult unless your doing it by yourself. Having a second person does make it so much quicker and easier but I've done it solo a few times.
Hmm, I would expect the quote to be around $800.
It should take a workshop around 3 hours to change a clutch (if I had a workshop it would only take 1 hour). So that'll be 3 hours x $120 (I think that's what they charge these days), so $360 for labour. An excedy HD clutch kit at trade would be around $300-$350 and $70 to have the flywheel machine. Add $20 for oil, which should total around $750-$800.
Anyway, PM me your number, if I'm close by Weston I'll ring you and take a look.
And most of my work is done on dirt. I use a few bricks and wooden planks, ramps, etc. All but one of my engine swaps were completed on dirt.
3 hours? damn I was told 5... how come it would only take you 1?
sent you my number in a pm in the afternoon
Of pull clutches on wrx's not sure how different they are but with them you take out the fork that actuates the clutch which is just a big bolt and then it's just like normal. The throw out bearing Is clipped in to the pressure plate fingers and u can't get it out.
I wonder what they are doing for 5 hours. It would only take me 1 hour if I had a workshop, because I would be setup to change Nissan RWD gearboxes (the only thing I currently own). I've done it many times that I know what to do.
I would be pushing it to do a 1 hour change on dirt. It would be closer to 3 hours if i had to get it done.
That Exedy is what's been in my car since just before I bought it. I think the receipt was dated March 2009, so we're getting on towards 3 years of use - just over 1 year of which has been at ~295rwkw.
I've slipped it badly a few times though, stunk like shit for hours hahaha. My bad.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
