Iv got a set of low km R33 GTR springs for my engine, but my engine is a throw away std RB20 so not worth the expense of new springs...your Rb30 i would be getting some nice aftermarket springs , i know of some new Greddy valve springs for an RB26 that are going for about $500 (i can ask if you are seriously looking for some, they may have been $50 either side , i cant remember)
im sure some sets of springs are more expensive then others, but i suppose its a matter of what you need, rather then forking out big money simply because they are a top of the range big name springs. Sorry im not really able to tell ou what a fair price is
  • Replies 285
OK well the time has come for me to stop talking and get it going. my only concern is fitting these things myself. if im going to do it myself i need to know whether im going to cause any damage or not! I have read into getting 1st piston to TDC. once i have done this, is it just a simple process of loosening the timing belt etc and pulling everything off and bolting the GTR cams in place? is there anything i should look out for. and while im at it would it be worth while going adj cam gears? (its begining to get expensive!)
Sydneykid: what sort of gains would you expect to see with this mod. is it worth doing if im only running a HKS2530 turbo?
What turbo set up is everyone running here?
Ive got a 2530 and just wonder what sort of gains to expect on a smallish turbo.
I should be getting my cams this week too! I figure while its all apart it is the best time to throw some adj. cam gears, so ill get some of the OS Giken ones that are pretty cheap at the moment.
so ill keep you posted.
Im out...not worrying about cams anymore, the thing is getting tuned and thats it. The old 170,000km Rb20 aint worth the money... all up installed and tuned it was going to cost me almost what a set of forged pistons are worth, got to start thinking about what will replace the RB20, ans stop spending money on it...still be great to hear the results.
Depends on engine condition and tuning, around 20 to 25 rwkw average power increase from 4,000 rpm to 7,500 rpm, boost about 5% earlier the rpm range. More power off boost as well, plus a nice little lump to the idle. and more growl as the rpm builds. Shoot, I do it just for the sound, the extra power is a bonus.
sydneykid they are some pretty awesome power gains considering the cost of gtr cams.
if thats the case i think i will get these babies in before i get the ecu tuned.
thanks for the info! oh and if its going to sound even better - hell yeah they are going in asap! hah
armbrusb, im having trouble with the std AFM signal maxing out and shutting the whole party down at anything over 1bar... i need to have limiter removed and possibly a Z32afm
OooH, I should add, as long as your turbo is capable of providing the airflow.
They sound like fantastic gains. Would aftermarket 256 or 264 cams offer much gains over the GTR cams?
No so much 256's, I have tried 264's, but keep in mind it is the extra lift that makes the difference, and you need valve springs to match. The 264's gave another 15 rwkw max power, but the usuable rpm range went up the scale. So we had to use 5,000 to 8,500 rpm to get good average power. This is not good rpm for a standard internals RB20DET with some k's on it.
The GTR cams are a good cheap and easy upgrade, it gets more expensive and risky the further you go.
Will be able to tell u what they did after the rest of the engine is back together and running, which will be this weekend.
Am running everything to comfortablely get 250rwks. But am only running a stock RB25 turbo ATM, until the engine is run in.
Like Sydneykid said, i would be happy if i just got some lumpy exhaust note out of it.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
