Ok so I had to rotate my comp housing on my turbo the other day and noticed the seal ( the one that seals the comp housing to the core ) is buggered is it safe to use silastic or a form a gasket goo type substance ?
Any feedback appreciated
generally sikaflex and 2way tape can fix anything in the right quantities :P
the real answer is a no unfortunately.. not recommended. But im sure the oring u broke isnt worth much, check ebay :thumbsup:
Red gasket goo on the external gate outlet...slightly caught fire on the dyno. Perhaps not the best thing to use that close to the hot side of an engine if there is oxygen present.
A case of, can you smell something burning?? Umm yep.
if its just an o-ring??
go see any bearing/o-ring shoppe. they should be able to sort you out. most silicone's are VERY heat resistant, and how they catch fire is a little beyond me. i have the red stuff holding the extractors together on my Bug. its gotten hot, and a little bit white over the years, but never on fire...i assume its pretty hot there as it gets a nice glow going on at full song (no turbo attached tho....yet)
It's not an Rubber o ring as such it's a ring but it's proper gasket papery stuff hahahah
And discopotato I can get them from mtq but I don't get much time to go that way so I was just swing if I could use what I had instead of going there but thanks either way lads
The standard one maybe Blake but this is a highflow turbo and it's definetly low quality gasket paper cause it fell to bits hahahah
but I have a spare turbo here so I might see if the factory steel one fits the highflow
Cheers for the input
seems a bit suss who highflowed it? wack the proper seal on there should fit if its the same turbo
Usually when you get to machined surface clamped together they will seal when clamped mate I would assume that it's the same thing with the Garret turbos .
The old v6 commos vn to be serries 2 never ran exaust mani gaskets because they were two machined surfaces so they sealed well enOugh with the right clamp pressure .
And Blake it wa done by one of the boys at mtq as an after hours thing hahahah so I'd say that's why the seal didn't get replaced an when I rotated the housing it just fudged up on me lol
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
