ANG Automotives
1/10 Malland St Myaree
93173025 (bookings required)
This is a private workshop. The guy who runs it (Angelo) is easy going and takes a common sense approach to things. Unlike the robots at the licencing centres.
Good luck!
https://www.sau.com.au/forums/topic/388737-yellow-sticker-take-your-car-here/
  • Replies 40
You'll actually find there are a few mechanics who can do this:
http://www.transport.wa.gov.au/licensing/21360.asp
I personally used Pebco to examine my R34 GTR, they were decent blokes and happy to help with instructions on how to fix any issues.
As well as allowed me to drive away, fix said issues and come back with no extra cost (on the same day).
Great for minor issues that would normally call for a full re-inspection at the pits.
Edited by j3rk
I got a sticker on my car last night, Will give these guys a try.
whats the sticker for?
I took my v36 there to get WA rego. The compliance shop didnt change over my HID globes before that. I told him straight out, but my car still passed.. Good bloke!
Moral of the story, as long as you dont go in with something obviously illegal or unsafe, you probably have a far better chance with these guys.
Also, in the event that it doesnt pass, they are a mechanics, so they can probably help you change/ fix things in order to pass. Saves you running from the licencing centre to the mechanics all day long wasting your time.
This new system should have been set up years ago. I think the original idea was to ease the back log at licencing centres from all the hail damaged cars coming through.
Edited by projectx
ANG Automotives
Good luck!
I have just moved to WA from NSW and need to get the rego transferred and will need to go through the inspection process because the car has a fair few mods, however nearly all of the modified areas of my car are only just out of specs according VSB's and regulations.
So how do they go with suspension heights and wheels diameters etc. that are only millimeters off what they should be legally?
Are most places anal about these things?
Licencing centres are anal about these things, if you catch them on a good day you might get lucky. Catch them on a bad day, and forget it. They will write a list of crap as long as your arm. Once that stuff has been recorded, it will follow you around no matter which place you try and reattempt it. After that, they cant just turn a blind eye anymore if you know what i mean cause its on paper.
Got the sticker for a shit load of things.
Atmo bov
No emission control
Screamer pipe
Pod
Tint
Wheels sitting a inch outside the guards
tint
There more but i cant remember it off top of my head. Meh.
Atmo bov
No emission control
Screamer pipe
Pod
Tint
tint
I went there and got raped. Defenately would not recogmend going there. Better off at the pits.
I got picked on every little thing and he wanted permits for everything..
DO NOT GO HERE
Well if you went with the above list, I'm hardly surprised...
There is no advantage in going to those approved mechanics if anything the pits might be better due to rushing. I had my sticker off at pebcos after second attempt. They failed me for my head lights being to dirty and the tint. The time before I went to pits and passed with ease they never even said anything about the tint. Pebcos spent over an hour on the car. The approved mechanics go over it more than pits.
The only advantage is the experience. The Pits suck for that.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
