PLEASE SHARE THIS AROUND!!!!
Our beloved family car was stolen yesterday from the Mount Barker (Adelaide HIlls) Park n Ride. 97 Rs4 V Dayz Edition Nismo Red Stagea Rego XKA 074........if anyone has seen or sees it please contact police and PM me......My babys pram was in it too :((( Thanks
https://www.sau.com.au/forums/topic/388866-stolen-stagea/
Dang!! i was hoping stags were still sleepy enough to not draw unwanted attention
Unfortunately quite a few have been pinched over the last year or so, not sure whether that's because people know what they are though
Always sucks to have something you've worked for and love pinched.. hope she gets recovered or if it doesn't, the process isn't dragged out too long
https://www.sau.com.au/forums/topic/388866-stolen-stagea/#findComment-6197359
Shit and this is just around the corner from me aswell as just down the road from the cop shop.. f**k im glad my skyline is behind the garage and 2 parked cars. Ill keep an eye out as i drive around the hills alot.
Thanks Adam.....Appreciate it Spread the word!
https://www.sau.com.au/forums/topic/388866-stolen-stagea/#findComment-6197484
Will keep an eye out. I would have thought there would be cameras around the Park n Ride area, possibly worth looking at.
There was an s13 stolen from mt barker Kmart at 3:22pm and the owner has video footage. Maybe worth contacting to see if he can spot your stagea at all, see if the two are related.
http://www.nissansilvia.com/forums/index.php?showtopic=516301&pid=6517008&st=0entry6517008
https://www.sau.com.au/forums/topic/388866-stolen-stagea/#findComment-6198138
Thanks...ive just posted it on the Silvia forum.
https://www.sau.com.au/forums/topic/388866-stolen-stagea/#findComment-6198213
THE CAR HAS BEEN FOUND!!!!!!!!!!!!!!!!!!
Cops just called and told us that the car has been found in Pt Adelaide. It was used to rob the Belair hotel. Getting processed, but apparently theres a fair bit of console damage and concrete blocks on the backseat.
https://www.sau.com.au/forums/topic/388866-stolen-stagea/#findComment-6199324
Sorry to hear made had my stagea stolen a year ago but i luckly got it back. Hope you get it back as you left it. If someone tries to steal mine again i am gonna revoke their birth certificate.
https://www.sau.com.au/forums/topic/388866-stolen-stagea/#findComment-6209690
  • 3 weeks later...
Im doing the quote for Steve to give to you to pass on if you get the go ahead for steering coloum and lock etc. I have no idea why they put concreate bocks in the back seat, and it's even tore the seats and door trims up.
As soon as he rang me saying i needed to come down and quote on a stag i thought it may have been your car. Hopefully everything goes smoothly for you.
https://www.sau.com.au/forums/topic/388866-stolen-stagea/#findComment-6234454
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
