This
Was plugged in to the clutch fluid reservoir (see marking in red where I've replaced with other line)
All I can think is that it was screwed in to help drain the reservoir away from other parts in the engine, anyone have any other ideas? Would hate for it to be some random workaround which was halfway through, and I've just disconnected it :P
Tha'd be your clutch master to slave cyl hydralic line...
I stopped in on Steve Caplice for a chat yesterday afternoon, and as savman said I need a few extra bars to meet current regulations for rally, which is what I need if I'm going for SI. As far as licences are concerned I'd need a clubman rally licence ($160), and then after log booking I can apply to transport for SI as a rally car.
I need some cross braces on the roof, as currently there's a single bar running down the centre. I have a feeling these could be pretty tricky/expensive to add in.
One I hadn't noticed but Steve brought up is the need for pillar reinforcements, as there's more than 200mm horizontally between the top of my cage and the rear (see below). I'm assuming these will be relatively straightforward to add in, but will have to talk to someone who has built a cage first.
Other than that I believe it all meets standards :)
Still tossing up whether or not it is worth it, for longer trips I would be towing anyway and I need to work out exactly how hard (and expensive) it will be to add the extra bars in. As the cage is already welded into the car and is pretty close to the edges getting full welds could be difficult?
He also said that as long as the cage meets standards that's the main thing they care about for cams, you may need to change a few things (he mentioned tyres) for the inspection,but engine, turbo, fixed position seats etc. don't matter as long as they're safe. I was half expecting that as it would be registered as a rally car I may need to downsize turbo/engine etc to meet rally standards, but he said that wasn't the case :)
I keep losing this document, so I'm shoving it here so I can come back and find it ;)
http://www.camsmanua...le_J_2012-1.pdf
Will add the current cage specs up in a few days for you guys to have a look at :)
yeah, since Jan 1st this year, cages must comply within FIA specs for log book registration. i applied for my log book mid-end of december before the cut off so i didn't need the extra bars (will get them at a later stage though) most of the changes are roof cross bar, a pillar bracers and 2 main hoop or rear leg cross bars i think, i leave that fiddly work up to my mechanic lol.
does anyone know if SI plates have to pass standard testing? eg: cat, charcoal canister, etc. what bout a front splitter or canards? they acceptable on SI rego if going to track?
atm with my car how it is, im gutted i wont make collinsvale this year :'(
According to the DIER website it has to be taken to an AIS for inspection so I would assume normal roadworthy conditions apply.
I believe cages in general go against what would be considered roadworthy, I'm not sure where it stops though. He said that the fixed position seats were fine (bolt positions welded to the floor) and I believe rails are required for a normal inspection?
You will need a mod plate for rego , not that hard to get and insurance will cover your car . If i were you i would register it as a 2 seater with cage , the turbo kit is what will need the plate as they came out with rb25
You sure he won't need the RB25 on the plate as well? I had to for mine..
Ah well I guess they'll soon tell him once he submits the modification application form.
r32's did come with an na rb25... so it's just the turbo that needs to be on the application, as Toff said.
I hadn't heard of this until a few months ago when I was trundling through DJRIFT's R32 build thread (never finished it, have to get back to that for some ideas as it seems to be a pretty awesome car), NA RB25's in R32 are pretty rare from what I gather.
Mod plates for the engine/turbo (depending on what I need) is a bridge I'll cross when I come to it, as it's a simple conversion (no modifications to the engine mounts etc) I have been told there is no trouble with this at all. I'm not certain on other things such as whether a cat is needed, though Steve didn't mention it he didn't specifically say that it was fine to skip one. I need to get a custom front/dump pipe made up, but I'm assuming it will just be made to fit with a cat/decat in place.
Small update: I received my GTR bonnet latch (so my bonnet will actually stay down now, rather than just sit there). I didn't realise before buying this car but the GTR bonnet latch is slightly further back, so you can't interchange the bonnets without either modifying the stock latch (which I've heard can be dodgy) or swapping for the correct latch.
While I was there, I test mounted the GTR grill and the front bar which has been lazing around in my shed.
Here's a photo of test mounting the manifold & turbo also ;)
Starting to look more like a finished car, my mechanic is coming around on Saturday to give me some pointers on work I can do myself and not tard up completely and work out what needs to be completed afterward. Getting closer to the track laugh.gif
Oh, almost forgot. This is the layout of the cage in my car in case anyone was wondering what I was blathering on about in my post yesterday.
Edited by Clandestine
You definatly need a saintz bar in a R32 (the extra one in the a piller), the front of the cage will collapse if you go over.
I need to look into pricing for this but I think I would have this done even if I don't go for SI. Looking at the cage design it looks like an obvious weak point and with my limited welding knowledge it looks much easier to get in than the roof bars.
Thanks for the info :)
Hey Guys
Im Jack Current manager of SPG ;)
As much as id love to I unfortunately don't own SPG but definately treat it like I do,
We are still running and have moved to kingston to be closer to Peter :P
Flick me a Pm if you like for any requests or add us on facebook
https://www.facebook.com/SPGarage
also check out our webstore http://www.spgarage.com.au/
not just need Savman,have to have that bar is now compulsory..
as was mentioned, any car where the base of the front leg is more than 200mm from the bend at the top of the screen it must be fitted.
this is measured along the the sill, measure from your front leg back along the seal 200mm if that top bend is further than 200mm you MUST have the bar..
the double roof bar is only needed if you plan to have a passanger, other changes are with the cross in the hoop, you used to get
away with a cross between the rear leg's, and a diagonal in the hoop, but now you need a cross between you rear legs and a cross in the hoop..
i spent 2 weeks of back and forth email's to get exact wording on cage design, as parts of the cams manual contradict other parts!!!
and as Toffy said you could get a MOD plate, but to do that you need removable intrution bar's, and it's a little to late for that now...
I own a hacksaw and an underdeveloped sense of what is right in the world, it's never too late for stupidity ;)
Thanks for the info mate, I think because rally generally requires a navigator the rally standard requires the extra roof bars? (but I could be completely and utterly wrong). I think the Sainz bars are also only required for rally also? The document is long and a little ridiculous, seems very easy to miss something, which could cost a fortune later on down the line... I think I'll drop in on Steve again at some point before I get the cage done to be sure, as he will be the one approving it :)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
