R33 S1 RB25 with nice deep gouge marks in 2 bores
mods: genuine T6725G 8cm, standard intake manifold, HKS cams/cam gears, NO VCT, RB20 loom and ECU
fuel: BP98
power: 311kw on 19psi
oil: penrite 15w40
useage: drifting
lifespan: have only done 1 event in it so far but seems strong, no blow by or anything
failure: none yet
E16C0E13-7A45-4DF1-81D6-4948F531E79F-252
Hey guys, can I join?
mods: 3" exhaust, greddy 600*300*76 intercooler, nismo fuel pump, nismo 740cc injectors, Hypergear ATR43 G3 turbo, low mount, stock manifold
fuel: e85 Caltex EFlex
power: 304 @ 17psi (clutch slipping so can't go further)
oil: Castrol Edge 10w60
useage: Daily driver - to and from work - occasional mountains flogging or track day
lifespan: Owned for 3 years still going
failure: None - touch wood
comments: So much fun!
Hi Tranman , I'd like to see your intake from the Z32 to the GTX3076R if possible because many claim its difficult to do .
Do we know for sure if the std GTS25T airbox can't support 300 RWKW , I still have mine and it has a cleanable Piper Cross element in it . I'd also like to see the box mods as I like stealth and I'm using the same IC as yours . The airbox in R33 GTRs must be significantly better if it supports more than 290-300 RWKW .
Good effort , cheers A .
Pictures (below) of what the workshop (Chasers Motorworks) did to open it up the stock airbox. They also fabricated the intake pipe to the turbo using a silicon hose joiner from the z32 to the 3" metal intake pipe before joining to the turbo via 3" to 4" silicon hose fitting. I was advised it was a bitch to do by the workshop.
The stock airbox was holding me back on my car hence needing to drill out holes. Not saying it will/may hold others back if they have better flowing setups etc.
Was tough getting a pic to show you the pipe from the z32 at this time, but you may be able to just make out how it reaches the turbo.
I looked up pics of the R33 GTRs airbox and it seems to lay on its side so there is a greater volume of air either side of the element .
Has anyone tried to use the 33 GTRs box in a 25T ? Probably a bit of stuffing around making a Y pipe but if you're doing something for a bigger turbo inlet ?
A .
Edited by discopotato03
i wouldn't worry about water... I ran my car like that for 5 years with no issues.
(not the hole cut in the stock airbox, but a pod in a custom box with a CAI from the front bar
    • If your current system is struggling to keep up, it might be worth considering AC System Upgrades. Upgrading can improve efficiency, reduce energy bills, and ensure consistent cooling throughout your home or office. I’ve found that professional advice makes a big difference in choosing the right solution.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
