ARTZ Posted May 1, 2013 Share Posted May 1, 2013 Yep I remember that, a mate of mine did similar - well more the doing mid 10s and 400kw on a stock motor (with just pump gas, no nitrous oxide, I must add) thing that the crowing and being banned thing This car has flawless victory, however: that thing is beautiful to watch, so smooth and unbelievably fast...its obviouslly well set up and a powerglide does help i guess but all I can say is....I WANT ONe!!! Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6835135 Share on other sites More sharing options...
GTScotT Posted May 1, 2013 Share Posted May 1, 2013 I assume the only weak point for now is the HG and if that goes I'll replace it on mine, if for some reason it's more terminal than that then I'll likely throw another stocker in its place... The NEO is a tough bit of gear and I hope it holds up Agree. If I were running a NEO at your level I would swap it out for a stocker once it failed. If I had more than 2 let go I would consider building from there. In the end you could go through 4 or 5 stockers before you reach the cost of building one properly. Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6835164 Share on other sites More sharing options...
copycutter Posted May 1, 2013 Share Posted May 1, 2013 Building a motor and only going for 300-400 seems like kind of a waste though The problem with it is, the motor is still susceptible to any one of so many failure points just like a stocker. Just takes one bit of carelessness or bad luck and then you have a very bad time. Seems like going "all in" in poker. Hence I give props to anyone with the balls and inclination to push a built motor. Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6835190 Share on other sites More sharing options...
34GeeTeeTee Posted May 1, 2013 Share Posted May 1, 2013 Agree. If I were running a NEO at your level I would swap it out for a stocker once it failed. If I had more than 2 let go I would consider building from there. In the end you could go through 4 or 5 stockers before you reach the cost of building one properly. Exactly! And it seems the Nissan seal of approval seems to hold together longer than a lot of "Builds" you see these days........ Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6835191 Share on other sites More sharing options...
GTScotT Posted May 1, 2013 Share Posted May 1, 2013 Agree with you both guys. I built my SR as the cost to me doing all the work myself was about the cost of two stockers anyway, so it was well justified. Plus I'm hoping to see more than what a stock SR will reliably do in the long run anyway. Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6835249 Share on other sites More sharing options...
Dinstg8r Posted May 8, 2013 Share Posted May 8, 2013 Haven't posted a recent 1 on mine... Now making 368kw from retune. much nicer and responsive thanks to Simon at Morpowa Stock internals, just bolt ons and e85(e-flex) Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6843717 Share on other sites More sharing options...
wolverine Posted May 8, 2013 Share Posted May 8, 2013 ^^turbo?? Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6843728 Share on other sites More sharing options...
Dinstg8r Posted May 8, 2013 Share Posted May 8, 2013 Gtx3076r tial 0.82a/r Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6843748 Share on other sites More sharing options...
Piggaz Posted May 10, 2013 Share Posted May 10, 2013 Good tuning and good fuel makes a big difference. When that thread was started E85 wasn't really available (and still isn't practical for lots of us today). Ethanol Content Sensor plus a decent ECU. There really is no argument of "it ain't close to me so I can't run E85" anymore. Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6846274 Share on other sites More sharing options...
wolverine Posted May 10, 2013 Share Posted May 10, 2013 In my case with two cars already set up and working pretty well the cost of buying a new ECU, bigger injectors, ethanol sensor and tuning does still make it impractical especially if the nearest E85 is 20-30mins away. On a clean install I wouldn't muck around and just go for it. Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6846332 Share on other sites More sharing options...
Adz2332 Posted May 13, 2013 Share Posted May 13, 2013 What turbo would you guys recommend for a rb25 running e85. Track car only!1000cc injectors power fc z32 cam gears profec 2 boost controller 3.5 inch exhaust Front mount Goal is for 8th mile drags!! So need response and huge mid range performance dont have a power goal just as fast as i can get down the 8th mile! Any ideas ? Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6848956 Share on other sites More sharing options...
Ke55pig Posted May 13, 2013 Share Posted May 13, 2013 Been awhile since i posted on sau .The neo out me drift car let go a couple of months ago running 320 rwkw BUT beleive this had nothing to do with the power im under the impression it pumped all the oil into the head and then left the bottom end dry spinning the bearing and chucking a rod. So got another standard neo to go back in its place this time it will be reciving some oil restrictors a head drain and a 7.5l gated sump to hopefully over come the oiling issuse . Also thinking of changing over to e85 see what itll make hopefully add some more reliability to it aswell. Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6848975 Share on other sites More sharing options...
34GeeTeeTee Posted May 13, 2013 Share Posted May 13, 2013 Been awhile since i posted on sau .The neo out me drift car let go a couple of months ago running 320 rwkw BUT beleive this had nothing to do with the power im under the impression it pumped all the oil into the head and then left the bottom end dry spinning the bearing and chucking a rod. So got another standard neo to go back in its place this time it will be reciving some oil restrictors a head drain and a 7.5l gated sump to hopefully over come the oiling issuse . Also thinking of changing over to e85 see what itll make hopefully add some more reliability to it aswell. Ouch Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6848983 Share on other sites More sharing options...
Ke55pig Posted May 13, 2013 Share Posted May 13, 2013 Ouch This happend on the skid pan after about 3 mins of 5000 -limeter of third.So it was under some hard conditions.see how the new engine holds up and see what it can make with some fruit juice Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6848988 Share on other sites More sharing options...
34GeeTeeTee Posted May 13, 2013 Share Posted May 13, 2013 This happend on the skid pan after about 3 mins of 5000 -limeter of third.So it was under some hard conditions.see how the new engine holds up and see what it can make with some fruit juice Well that explains a bit Nice one haha Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6848992 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted May 13, 2013 Author Share Posted May 13, 2013 This happend on the skid pan after about 3 mins of 5000 -limeter of third.So it was under some hard conditions.see how the new engine holds up and see what it can make with some fruit juice i'd say your diagnosis is spot on then! lol RB's without custom drains and restrictors don't like 3+ minutes of limiter much at all hahaha Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6849886 Share on other sites More sharing options...
SCR48 Posted May 13, 2013 Share Posted May 13, 2013 (edited) Just broke into the 300kw bracket.... R33 Series 2 mods:ViPec ECU Haltech Flex Sensor GT3076r .82 Low mount, Internally gated APR head Studs Metal Head Gasket 3" turbo back exhaust Walbro 400L pump Tomei Cams 740 Nismo Injectors fuel:E85power: 450hp [335kw] on 24psioil: Motul 20W-50useage: Used to be daily, making its way to cruiser statuslifespan: had it for 4yrs, bought stock as a rock. failure: Had head problems in the past when running 350hp on pump98comments: Gains for E85 was 105hp over my Pump power of 346hp on 20psi. Next mods will probably be new clutch, injectors & External Fuel setup Edited May 13, 2013 by SCR48 Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6849910 Share on other sites More sharing options...
copycutter Posted May 13, 2013 Share Posted May 13, 2013 Woo! Awesome gains on e85. Welcome brother. Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6849958 Share on other sites More sharing options...
34GeeTeeTee Posted May 13, 2013 Share Posted May 13, 2013 Just broke into the 300kw bracket.... R33 Series 2 mods:ViPec ECU Haltech Flex Sensor GT3076r .82 Low mount, Internally gated APR head Studs Metal Head Gasket 3" turbo back exhaust Walbro 400L pump Tomei Cams 740 Nismo Injectors fuel:E85 power: 450hp [335kw] on 24psi oil: Motul 20W-50 useage: Used to be daily, making its way to cruiser status lifespan: had it for 4yrs, bought stock as a rock. failure: Had head problems in the past when running 350hp on pump98 comments: Gains for E85 was 105hp over my Pump power of 346hp on 20psi. Next mods will probably be new clutch, injectors & External Fuel setup Why the upgrade of the injectors and fuel setup? Is it on the limit? Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6849968 Share on other sites More sharing options...
SCR48 Posted May 13, 2013 Share Posted May 13, 2013 (edited) Why the upgrade of the injectors and fuel setup? Is it on the limit? Injectors are reaching their limit for E85, I upgraded my fuel pump tihs week from a walbro 255 to 400 to handle the E85. More of a bandaid till i have the $$ for a full external setup. 255 fuel pump was maxing out with the car makeing 405hp and a mix of 70% pump98 and 30% E85. to get the full benefits of e85 it needed changing With the Haltech sensor i can now run any blend of pump to E85 i like and the tune will change accordingly. Very surprised by overall gains Edited May 13, 2013 by SCR48 Link to comment https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/page/28/#findComment-6849983 Share on other sites More sharing options...
