Got mine from Greenline, to be fair I can't remember what duty cycle they were at but I remember working out that it would be a stretch trying for 17psi on E85 with them on the GT3076R
Sent from my GT-I9505 using Tapatalk 2
I don't recon the 555's would make it with the 3076 on e85
with the 2835 they were reeeeeeally stretched and i didn't personally want to mush them any further.
@ 323rwkw and 20psi we hit the point of diminishing return on the power figure so we called it quits anyway
I had 550's and was told to go too 1000's which i did! Turned out they were incorrect and dodgy and have now been replaced by 2000s :P A bit of headroom now haha
That's very decent for 555's. From memory my Nismo 740s were @ roughly 80-85% on last tune at 304kw with a bit of thickness up top. Enough for what I want but not a hell of a lot more.
I don't know if the nismo injectors have a nicer spray pattern for low rpm/load than ID injectors, but at least I have enough flow for the job either way.
Ok guys, noob question in regards to 200L drums of fuel.. It's got a proseal cap and for the life of me I can't get it undone. Apparently there is a proper tool but ppl open them with screwdrivers. I've tried a lot of tools even tried having two vertical screwdrivers and one horizontally between them to twist and it still won't budge.
Anyone with tricks to the trade for this?
you tried heating the lid and using a pipe wrench.Nothing has ever beaten a pipe wrench with my strugle to undo anything
TBH i think Nismo probably just make 740's and paint them different colours
I wish it were true for mine, I had Nismo 555cc and they behaved exactly like you would expect 555cc injectors to behave - as I mentioned earlier... meant I wouldn't get away with ethanol :(
Soft! :whistling:
This here is my unopened rb25. Has a surge tank,
044 pump, 750bosch injectors, e85 fuel and an apexi
Power fc. Turbo is a hks 3037 .63 rear housing with a
Garrett front cover. Tuned by smmotorsports making
344.1rwkw on only 15.8 psi. Since October last year
I've done 5 drift events, Phillip island sprints and
Winton Vic time attack over Easter. Engine still has
no signs Of wear.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
