My engine is still going strong! 11000kms on over 350kw now :D
man those R34 NEO motors are built like german nazi tanks lol
it seems like it's more economical to drop in a R34 NEO motor if a R33 RB25DET motor ever carks it
They tend to hold together pretty well! Ill admit mine has had a hard life too! Its been overheated (Well got warm but Haltech shut it down) and also had a LOT of fuel dramas which caused all sorts of bad AFRs early days... I try to keep it off the limiter but it still gets spun to just over 8000rpm when up it haha
Sick effort. Mines close to getting on the rollers. Patience is running thin though
It gets like that! Itll all be worth it on that first drive though ;)
Funny thing is I'm the one doing all the work. Just a matter of putting in the effort after working all day on shitbox cars (skoda). Sometimes all you wana do is sit on the couch and not move lol. Will be tuned within the month though
I would like to be able to say the same. But i give mine a fairly hard time. Seen 2 track days and lots of limiter, although mine is set at 7450 from memory not 8000 haha.
Even driving it very hard, no blowby AT ALL! or any oil/fluid leaks, just running the standard nissan setup. ie linked rocker covers and then a hose to the intake after the AFM.
The thing i am most impressed with is its off boost driveability though, it is insane! Put your foot down in any gear and it just accelerates, even crusing at 100 in 5th, half throttle and it just accelerates to 120 easily all while off boost!
I am certainly very impressed with the NEO!
Unfortunately mines dropped cylinder 5 :( flaming mongrel!! Im not sure what caused it, had plenty of vacuum leak drama from the plenum in past year and an accidental overboost of 25psi in third, all cylinders 155-160 and number 5 is 60..goes upto 200 with some oil squirted in.
rebore and forgies n rings or drop a stocky? thoughts?
Edited by AngryRB
I thoughtyou sold your 33? You building another or same but different way? Id throw pistons and rods at it but all depends on your power goal and what you wish to do with it.
that was the plan, but then discovered the dropped cylinder and now thinking ill just have another crack at it, will be a 300kw and ethanol , keep it very simple this time with a 0.63internal rear
Edited by AngryRB
forgies...and 500kws...:P
Yes and no, depends on your powergoal. You've got Matty spinning up 390kW on a dead stock motor and it also gets punished. I've sbeen how he drives it lol
So why spend thousands when a drop in NEO will cost you half the price of a basic engine rebuild?
Just my thought.
I have 2 mates that had 300rwkw 25's for the same time I did, one drivin like mine, the other PUNISHED. both of theirs were built motors from very well reputed workshops, and both of them are on their 3rd motor now. while mine was on it's second when I sold it
with these power figures its a lottery either way, so i'd just got another stocker personally.
car is dedicated E85, its a big decision, having thoughts of running a higher comp ratio of mid to high 9s, gt3076 with .63 rear internal, goal is driving on streets and drags with reducing lag and making it feel very punchy on the street. 300-320kw max
stocker- solid from factory but still old and 155av comps..
rebuild- new pistons/rings ( possibly forged) and have 180-200 comp = more grunt and earlier boost for the streets
much simpler to just drop stocker in though and maybe shave a bit off head, don't want to overcomplicate stuff
Edited by AngryRB
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
