Hey guys,
Never made a dose pipe before but i have just turbo'd my mates 31 with a T3/T4 T04E and was playing around with various suggestions i found on the net but with no success, anyhow he isn't really fussed whether his dose's or not but i am about to turbo my 31 to give to my girlfriend and she really wants it to dose, so if anyone could help me out with some measurements or even better, pics..that would be awesome :rolleyes:
Thanks, Daniel.
https://www.sau.com.au/forums/topic/389832-help-making-a-dose-pipe/
2.5" Silicone Joiner, 2.5" or 3" wide, 17cm long piece of pipe preferably 45 degree angle, Attach to mouth of turbo, attach some memory hose to the end. It's actually the easiest thing to make, if you need measurements then you probably shouldn't be doing it :P There is no "Right" way.
Ah cheers mate, i tried a piece of short 3" steel pipe, also a reducer and short 2.5" steel pipe, and also a couple of different sized elbows, all i could seem to get was the usual compressor surge noise >_< i wasnt driving it when i tested it though, just revving it
I've fkt around with dose pipes for about a million years now.
I had the same turbo on my VL.
The best dose I could get was a 3" > 2.5" reducer to a straight pipe 11cm long with no pod on the end.
Any bends take the volume right out of it and making it longer makes it deeper.
i wasn't able to drive it as it wasn't finished yet but i was able to get it to surge pretty easily by revving it like in the video above ^ ... but i will drive it next time just to be sure.
Also what is clamped in the end of that pipe peter ?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
