Ok so the above was a fail, still getting plenty of oil in the catch can (about 100ml per lap) so back to the drawing board.
Luckily (unluckily but I'm being optimistic) I went to the track the other night in the wet and the excess front wheelspin has lunched the front diff so the motor is coming out. I have a Greddy extended sump so I'm now planning on getting 2 x dash 10 fittings welded to the passenger (intake) side at the front above the oil line. Going to remove that other line to the rear turbo oil drain and just blank it off again at the same time at it didn't seem to help.
I plan on one of the dash 10 lines going to the top of the catch can next to the cover breathers as a sump breather. The other will get plumbed to the bottom of the catch can with a one way valve (no spring) to act as a drain for any oil to drain if and when it does reach the catch can...
Am I on the right track here? Works in my head
Yes. If you read the last few pages of the big thread http://www.skylinesaustralia.com/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/?hl=sk%20oil%20control
you will see that worked for me. You can also run the cam cover breathers to the same catch can and then instead of venting the catch can to atmosphere run a line to the turbo intake - preferably via an air/oil separator (or in my case just a second catch can). Do you have an oil restrictor in place?
Just read your plan, almost exactly the same plan but you didn't mention if you put a one way valve in the catch can drain?
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
