when you get a HKS exhaust and it says Jasma that means its considered road legal in japan
atleast AFAIK anyway, not like any of us have a japanese handbook to rules and regs lol
elrodeo666 could probably clarify if he saw this
I can't get the link I'm on my iPhone it is the type of mani I'm looking for puts the turbo between cil 1 and 2 also has a external waste port it all seems good made from 304 stainless 2.5mm thick. I was going to make one for my sr but this looks the goods even has a t3 t4 flange
yeah, I know they make those fancy manifolds tuned lenght cause it helps with spool up times etc..
But I have been wondering lately if log style made to roughly the same dimensions as the stock manifold but with larger ports/runners .
If it would actually flow better than the stock cast item ..You,d think it would have to flow as well at least..
you could mount the turbo up on a bit of an angle and have the gate path flow out underneath it..
here this will get ya started.. :)
http://www.ebay.com.au/itm/RB25-TURBO-EXHAUST-HEAD-FLANGE-NISSAN-/280816991408?pt=AU_Car_Parts_Accessories&hash=item4161ff3cb0
How much power/boost are you after, if your thinking of a log style manifold i would assume not much, maybe look into extractors and rear/remote mount the turbo, would make things a lot simpler and it would hied the turbo.
yeah thats another idea..
But why couldnt you boost it with a log??
stock mani does alright with 20psi..sometimes more
You mean stock turbo manifold or stock non turbo manifold?
The flow would slowed for a log style manifold at high boost (even at low boost but not as much), if you do a log style and then upgrade to a proper turbo manifold you will notice boost being made a lot easier and quicker with a proper styled turbo manifold V's log style, if you have the know how and tools to make a proper manifold then do it that way, if not i would go extractors and rear mount, i personally wouldnt bother with a log manifold unless its something you have sitting there and a dump pipe to suit.
I want the turbo sitting between cil 1 and 2 as there is not much room because of abs unit in the BMW for my td06 to sit. I made up a cad drawing of what I think would work well I'm not after massive power all be happy with 260 same power that was in my 32 I'm hoping full boost by 4200 18 psi. The design I'm looking at making will be the sr20 manifold reversed the turbo will sit up top allowing the gate to run underneath the mani so hiding from the unknown eye. Basically if I was to cut the flange off a stock manifold and turn it over that's ideal for me but to hard to controll being cast
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
