Hey guys, recently bought a r34 gtt and I've found when hitting high boost the engine light flahses on and off until i let it off boost.
It has a Z32 and a power FC and is on half a bar of boost.
Previous owner said it is tuned to run on 98 and I put a quarter of a tank of 95 (couldn't find 98 at the time), could this be the issue as the tunes set up for 98? or could it be faulty AFM or something else? I'm scared to put my foot down in boost, don't wanna break anything. >_<
Any help is appreciated :)
Put octane booster or 98 in it before putting your foot down if it's tuned to run 98 its a must I suggest not driving on boost at all as it will be running lean
Edited by Bsa
Your engine is knocking. If its tuned for 98 and you have no other choice but plain old 95, dont push it at all.
If you push it you risk detonation damage to your pistons if it happens for too long.
Engine light flaahing is the pfc telling you its knocking. Do you have a hand controller?
Ty.
+1, your engine is pinging and it is extremely dangerous.
turn the boost down (or even off), don't use full throttle until you have refilled the tank with 98.
If it still pings (light flashing) after a new tank of 98 octane, you need to get the computer re-tuned on a dyno
Just use the hand commander and pull a couple of degrees timing out of it until you can do a complete fill with 98.
Go Settings then Ign/Inj and take some timing out of it.
These temporary changes are deleted as soon as you turn the engine off, all good, tune is unaltered.
That's what this function is for, trial tweaks that can be instantly erased.
.. Going on the assumption that he has a hand controller.
Definately a good band-aid fix for now, thats for sure. Dont wait until you're on empty to put 98 in.. Might as well do it now. You might be diluting the 98, but 96.5 (as an example) octane is better than 95.
+1 what Duncan said. You might as well get it tuned up anyway. Preventative maintenance is always a good thing.
Ty.
Blake using 95 won't make it run lean but 95 has a lower knock resistance.
OP has the engine light ever flashed before with 98 octane?
the engine light can flash due to :
high knock
afm maxing out
injectors maxing out
i doubt on 7psi that the inj or afm are maxing out..
do you have a hand controller?
just bought the car... it's got a boost controller and another gizmo to do with the power fc... it's only on like .6 bar. not sure if it flashed previous... Been driving it around avoiding boost and I'll fill it tomorrow a full tank of 98.... think it has about a quarter on the gauge of 95
will be booking it in for a service next week at chasers n see what they think if the 98 doesn't fix it by then and just drive the daily til then
thanks guys appreciate the help!
Or maybe the previous owner just installed a PowerFC without doing any tuning. The stock ignition map is super aggressive on them.
When he/she said tune, did he or she just poke about with the AFM setting and part of the injection map?
Take the return line off the arse end of the FPR, put a longer hose on te reg, start car and drain into a Jerry. Put the fuel in the daily and fill up with 98.
Job done.
this. unless your patient enough to drive it sedately until empty, which most people arent.
dont use any sort of octane booster, will only cause more trouble.
I wasn't suggesting he use the stock ecu all the time... Just suggesting he try it out to trouble shoot and see if the engine light still comes on under boost. Like trying a different AFM to see if your AFM is stuffed..... Try a different ecu to see if its the tune/ecu or something else. Considering the current owner bought it this way it may help it may not. If he is going to get it re-tuned why not get it tuned on a lesser octane fuel then always use 98 octane?
The stock ecu doesn't flash the engine light when it knocks. I really doubt there is a tune on the ecu. I recon its the stock pfc map. None the less, your car is pinging. Change the fuel or use the hand controller to get rid of some timing.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
