Is this the successor to the terrano II? it looks like a small suv like the dualis, have nissan sorted out these issues with the juke?
Nissan is recalling 28,294 2011 Juke models to fix a sensor bracket that may separate from an air inlet tube. The vehicle may go into "fail safe" model and the warning light will turn on. If a driver continues to operate the vehicle, it may stall during idling and in rare cases may not restart.Nissan said its testing over the last year in the U.S. showed that the vehicle would not stall without warning at higher than idling speeds. But Nissan said it has seen recent incidents in foreign countries of vehicles stalling without first going into "fail safe" mode. In those cases, the vehicles couldn't be restarted. Dealers will replace the air inlet tube if necessary. The vehicles were built between April 2010 and May 2011.
source: lemonautos.com
^^yep i hear you there. i could almost talk the other half into one with an auto though
she doesnt like the stags or cubes but wants something styled like this. they would have to be high 20'S or above wouldn't they??
cost though- think about it. whilst I understand what you are trying to do have a look at the Z11 market. these things are still sitting in lots at $15k and from my understanding are a bit hard to move.
I can't see a $20-25K juke going anywhere fast myself. if the mainstream guys (and the ones we have in common) get them then its going to be a minefield trying to find one thats straight and not wet.
seems someone has a different idea in brissy. I saw a early toyota Will V putting around today with a trade plate on it . I think gearing was driving it.
Alphard ....... what happened ?
Find me an article and I'll submit it!
Yeah but you're old and you don't get that young people like Jukes :P
I've got someone in Sydney prepared to drop folding on the test car and pay for all the testing too. Like most newer cars, they may not be a good bet now, but they will be in a couple of years.
I must have stopped aging then :rolleyes:
...if this is anything to go by...
http://cars.about.com/od/nissan/fr/11_juke_preview.htm
Well, it's a start!
And I will laugh heartily if Gearing is seriously considering the Will V...
he already has a mitsi M there.. (fuel version of the MIEV) so if would not surprise me.
if you have someone ready to commit that sort of money then by all means. I still do not see it going anywhere myself.
most of the guys I know have moved away from cars and gone to motorhomes,bikes and US iron.
and yes I am old :P
The missus would kill for a turbo manual in black... has to be a good grade and prefferably with leather.
... I don't want to be seen in a focus or golf :-( (comiing home from the pub).
pm comming your way Kris.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
