What are you looking for? With a good flowing head there isnt much need for cams in our engine, especially with a 6500 redline.
That said, I think the 3.5de cams are similar, will they drop in? Probably but dont quote me. You can come here and try if you like, I have a spare of each engine.
The VQ30 doesnt have cam adjustment, the VQ35de has hydraulic adjustment called cvct and the VQ25 has evct. Not sure if the cams are the same though, perhaps the actuator mechanisms are different but they bolt to the cams the same way?
I still havent gotten around to fitting the 25det heads to the 3.5, not sure they fit yet. Do you know? Why not just use the de heads?
DE heads would be easier in your franken-engine, and easier to control with Engine management.
I'd say you'd have a lot of trouble getting the ECU to control 4 electronic cams, rather than two hydraulic ones. But its up to you. What car is it in?
How do you know the 25 heads will fit, have you done it yet?
http://www.skylinesaustralia.com/forums/topic/342662-vq25det-to-vq35det-conversion-in-m35-stagea
We have already told you most of this info and you dont seem keen to elaborate on what you plan to do or why...
Jetwreck: More revs required to feed a bigger turbo...
Scotty: They will bolt together, yes.
How did you go with the 3.5 install? Was it all you hoped with the stock 2.5 turbo?
Bullshit. You dont need a 1200hp turbo, a GT35 will hit nearly 400kw, come on at 2500 if done right, and not have to rev past 7k. Revs over that are just wank and damaging your engine, not to mention costing you a fortune. What is your power goal anyway?
Like I said, you need advice but refuse to give us the information we require to help you properly. Dont just listen to your workshop, they dont know all as you have found out.
what are you doing with this car.
1. I am tracking and I don't need more than 300AWKW's and 6,800RPM
2. Scott is chasing HP and straight line because his gay and doesn't need more that 7,500rpm to crack an 11!
3. Your trying to achieve what?
you have so many issues that you will need to get past mate......don't want to see money thrown in the wrong direction.
There's not a whole lot in the way of aftermarket support for our platform. Some workshops I approached didn't have the balls to touch the Stagea. However, my current workshop has done some amazing work on the car, turning the seemingly impossible into reality.
Those two times I've made enquiries on here, that's just me doing some private research, exploring certain possibilities. My workshop will make it happen.
Did they explain to you that aftermarket camshafts will make the turbo spool later, moving the power band further up the rev range? Its only useful if you plan for well over 400kw imo and losing midrange sucks.
At the end of the day a built auto wont handle much beyond 300, do you have the coin for a Getrag conversion?
The stock manifold wont support that sort of power either so I guess you are looking at twins? You will have to ditch the Attessa which makes that much power useless for the street.
I also have doubts the 2.5 will fit on the 3.5 block without first modifying the head chamber as the pistons are much larger, besides the 3.5 heads will flow much more than the 2.5 ones ever will, you just hit the actuaton brick wall and without the cam actuation the engine is very lethargic (as you may have already found out.)
Quote: turning the seemingly impossible into reality.
So what is it they have done for you? I can understand you want to keep it to yourself as you would be paying through the nose for the workshop to learn the engine's characteristics, but it doesnt help the Stagea community to keep secrets now does it. After all, this forum IS the aftermarket support for this platform.
Please dont take this as a personal attack, I only want you to know the path you're choosing may be a long and costly one.
Yes we are aware aftermarket cams will do that, and we're looking for far more than 400kw, on a stroked 3.5 block, custom manifolds.
The 2.5 was fitted on the 3.5 block by a previous workshop. They gave up, job half-done (needed engine management and tuning). The car drove, albeit in limp mode.
It's not my intention to keep secrets. Far from it, I just dislike babbling about things that aren't finished. Once I'm confident everything works I'll be more than happy to share. Results > talk.
A picture > 1000 words
Edited by dcdc
RWD I assume? Good luck with traction. :P
What are your plans with it? Full standalone ecu now with twins for that power I take it?
I still dont think you should be upping the revs though.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
