Hey guys so I got 2 issues that just came about when I put my 2nd hand radiator in.
1st. It has hoses on the bottom of it for power steering I have just left these as my car doesn't have hoses running to power steering from the radiator.
This wont cause any issues will it?
2nd. The outlet from my engine to my radiator is rusted so badly now when I tried to clamp it back up it just crushed and leaks.
I now have no where to connect the hose from my radiator to. Ideas please?
All I could think of doing was pulling the whole thing out and taking it to get a little section of pipe welded onto it.
https://www.sau.com.au/forums/topic/391336-radiator-rusted-pipes/
  • Replies 50
Looks worse than the one I pulled off my car. :(
I ended up having to replace the bottom half of the plenum, which I brought from the forums here. Its a big job as lots of the old hoses connected to it become brittle over time, involves a few gasket replacements too.
But in all, I don't see why It couldn't be repaired, someone should be able to fix it up for you.
Edited by Chris Shaw
Hey Chris
You werent able to get yours repaired??
Im worried about what the hell the inside of the engine looks like
wow never seen that bad before. Maybe there's something to puttin distilled water in.
Sounds like your best action would be to do the same as above. I think repairing would be a temporary bandaid.
As for the rest of your engine put your old radiator on and flush it with a chemical flush. (old rad can be used as a filter :) )
PS. Shouldn't be exy to get another plenum and there is a few old 33's wrecking in canberra.
How does this shit even happen??
That is some nasty corrosion you got there fella.
When my Rad was leaking and I ended up replacing it with an Aluminium one, I did a heap of searching on here to find out what I could.
Being the eternal Noob that I am, I am thinking perhaps it has been caused by:
a) not enough (if any) anti-freeze / anti-boil in the cooling system. There is anti-corrosive additives in it to stop rust etc.
b) Old coolant loses its ability to work properly and therefore can lead to corrosion of the system.
c) Using tap water in the system instead of distilled water. The impurities in the water cause corrosion.
d) air bubbles in the system.
e) stray electrical current in the coolant (caused by bad earthing) can cause electrolysis which will eat away at metals and make them corrode away, especially when there is different metals involved. Brass or aluminium radiator with alloy head, cast iron block and perhaps whatever metal that pipe was made of.
As stated, I am the eternal Noob and some of this info may be a little blurrrred (correct me if I'm wrong), but I reckon there is a good chance that some or all of these things may have killed your pipe...
I wouldn't know where to check all the earths
My system has had bubbles in it for the past 3 months that I have had it because of the leaking radiator that I only just replaced
Could have used tap water while it was over in Japan
Someone said they are pretty cheap over there with that kinda thing
It's a stock radiator so Shouldn't have issues like the aftermarket ones might
I think stockies are brass so they are still a different metal to the rest within the cooling system.
It would be worth checking for stray current in the coolant to hopefully stop future problems and check earthing in the engine bay to try to eliminate it if it is there. I got Gibbs Auto Electrical Services in Belconnen to install my Rad and they did check for stray current etc... All was good.
Good luck with the fixup though. I hate to hear of broken SKYLINES. :(
Edited by Not a Pulsar
Just checked my receipt, cost $100 labor to fit Radiator, new hoses, new thermo, flush system, check for electrolysis and road test, so It shouldn't be too much.
I found these pdf files which might help you D.I.Y.
electrolysis.pdf
Cooling%20System%20and%20Electrolysis.pdf
Hi again, I didn't really look into getting it repaired, I found the bottom half of a plenum for $50 and just went straight to swapping it.
As for whats in the engine, I did a coolant flush and replaced my radiator with an Aluminum one at the same time, have had no issues and it has been a good 4 months too.
If you need a quick fix, I still have the bottom half of my plenum in my shed, it has enough pipe to put a clamp on and seal with no leaks. - Freebie of course.
I have an aluminum radiator in mine that was put in when it got a big service round 82,000kms. It looks good, and i think prob works better than the original.
Radiator fluid is cheap, it is a good idea every year or two to use a hose and flush out the radiator and engine cooling areas and re-do the fluids.
Honestly, do the fuel filter, break fluids, powersteering ect every once and a while too, they are not heaps expensive and the little things make the difference and increase the life of your car.
Best luck with this horrible messy situation!
Firstly the lines you're talking about for power steering is an auto trams cooler built into the bottom tank. If yours is manual don't worry about them.
Secondly, DANG! That pipe is nasty! No wonder you radiator was stuffed! Your cooling system and block needs some serious flushing (packed full of rust, scale and debris). I dare say u did t have any coolant in there at all. Get yourself a good coolant (antifreeze/antiboil is not a complete coolant). I would replace that whole assembly and fill the system up with just water and some radiator flush, run the car up to temp for 20 mins with the heater on. Then drain that shit out, replace your thermostat and put 33-50% coolant to water ratio and ya set (unless I get premix which is already around this ratio). AFAIK nissans coolant change intervals are every 40k. When was your water pump last changed cos I hope it doesn't look like that pipe ;) haha
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
