So as people may have noticed, well those who live in NSW, Penrith got flash flooded last Friday, and well it got into my my car. I had to drive it to go get a plane, then back home tonight from my mate's place who lives near the airport. On the way home the battery light came on, so I assume that this is a dead alternator not charging the battery, but after that my hicas light that stays on permanently (hicas bar in the car) was flickering and my steering got heavy, is my power steering pump likely to be gone as well or is it maybe just run out of power to run it? Also if anyone has an alternator for an R32 gtst, how much do you want for it!
Thanks guys.
https://www.sau.com.au/forums/topic/391621-floods-and-now-issues/
I suggest you get your seats cleaned properly man, if there is any moisture in the seats and its forming mould, that could be deadly man. If that shit grows in the seat and you get dust and other crap coming out of it and you breath it in, its not healthy.
I do plan to, I did dry them out pretty well so I'm not too worried about the moisture, that was just from rain as I had left my windows down that day, the flood water didn't quite get seat high.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
