I am pretty sure they are dual filament. The look like the same ones in the eBay link for high beams posted above.
I have also got my HID cables from a member in here for $35 inc shipping. He also has ballasts for Dog with Bone $70. I should have them on Wed.
'Cider time' if you can assist us again! I was wondering if it would be better to install them at night to be able to adjust the angle of the beam?
Can't wait to fit them! Wish I had not seen the 2006 rear Tailights in the weekend. Now I want a pair of them! Any idea where I could find them?
  • Replies 478
Rear 06 lights from perry-infiniti
install light during day so u can see what your doing... all you need is a screw driver and you can adjust level when they are in the car.
Pretty sure no H1 is dual filament
Edited by R6n350GT
I also need the HID cables, able to find another pair for me? :)
Sounds like the coupe lights have been more of a hastle than my sedan's ones... Mine literally plugged straight in.
Nah, not really... Just depends on compliance, the others and myself had ours hacked and taken out. That's why we gotta get other parts for it to work. Just wished compliance didn't touch my car and left everything as it is...
Has anyone tried adjusting the aim of their low beams in the new headlights? I supposed it's the top adjuster on the inner side of the housing (closer to engine) right? I tried turning it in both directions but it doesn't seem to make any difference.
Got my HID cable so I am ready to go. Just not sure about a couple of options from the install. I also got some 2006 taillights (I wish I had not seen them on the weekend!). If anyone needs a set of mint 2004 taillights PM me.
Andrew is there a chance of us getting together over this weekend or next to do the other cars? I am confident of putting them in but not adjusting them or various wiring options. Can bring cider ;-)
I didn't fit a halogen in a hid socket, the sedan version of these aftermarket units came fully halogen equipped bulbs and all, just gotta adjust my high beams other than that completely plug and play :)
Sedan headlights are complete aftermarket, so the low beam globes are H7- not the factory D2R type.
The coupe' lights are either a modified OEM headlight or more than likely a copy of the factory ones, hence the retention of the factory HID setup.
I haven't been following, so what's the reason for adjusting the beam? I thought this was a JDM right hand side driving headlights and it was set already?
If yours levels up ok then you don't have to adjust anything. You should check the aim against a flat wall to make sure both sides are even and at the correct level. On mine the right side is lower than the left so I want to raise the right side to be even with the left.
Mine shines down way too far on the ground .... this results in oncoming cars seeing a reflection of the projector light beam on the actual chrome housing of the light below the projector = dazzlingly bright for oncoming cars.
Eh..I thought it was normal for it to be lower a bit on the right..just to ensure that it doesn't blind oncoming cars.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
