Hey guys,
I've booked a skidpan day for 16th May,
I know a few people who may be interested in this - myself included.
The sessions are $149 per person, and limited to 12 people.
Either 8.30am-12.30pm or 1pm-5pm. We will be going with the morning session
Included are driving instructers, who can give some tips and help you out, including riding in your car with you.
You don't even need a day off work, its on a SUNDAY!! What I do need ASAP, is a $49 deposit, or someone will take your spot
I currently have 9 people confirmed for this event, so I need another THREE (3) people who are interested in the event, and able to give me a $49 deposit
Let me know if you're interested :mad:
Rick
https://www.sau.com.au/forums/topic/39213-16th-may-ec-skidpan/
  • Replies 63
We'll see how this one goes, if I can't get the numbers I'll have to knock it back
Had the full dozen people organised before but some people are not as serious about it when it comes to getting serious :(
Its $149 for the morning session..... only 12 cars tho :)
Full now, thanks :)
skid pan is so boring, all you do is **** up your car, and if you cant learn to to drive your own car, then i dont think an instructor will help you, sorry guys i just think its a waste of time and money to go somewhere just to rip hellies in the wet and try to control it, you can do that on a rainy day( for you people who have balls)
I don't even know how to respond to that verbal diahorrea.
Your doing a fantastic job in cementing yourself as the biggest tool on this forum.
I reckon its the best way to learn how to control understeer and oversteer, plus it's handy to slide out spin and lose control when there is no gutter/tree/car/person/etc etrc to possibly collide with.....
I had an absolute blast the last time i went on the Skidpan.... I feel that my knowledge of the car increased 10 mill fold. Now i know/can predict, when my car is likely to spin out.... what understeer feels like and how to control it, plus IT'S LEGAL FUN.
On a second note.... I reckon "L" and "P" platers SHOULD do a course on the skid pan and Figure 8 track, to help them understand that not all car's are like the one's in the movies... and to also show them how easy it is to get in to trouble.... but that's a different thread....
Cheers
Lawrence
omg....i don't think you have ANY idea about what you are talking about. I don't even want to know how many people you kill in your car! or how you kill your car...cause with your attitude, thats the direction you're heading in!
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
