  • Replies 162
  • 3 weeks later...
Who wants the rest of the wreck it includes passenger seat, front Gaurds, 4 doors, tail gate, bonnet, grill, front bar, rhs wheel flares and side skirt, lhs side skirt, glove box, heaps of trims, and much more.
come and pick it up for $300 (needs to be dragged onto a tow truck)
Call Chad to arrange a time
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
