  • Replies 43
He couldn't help me when I cooked my RE5, he may be good with RE4's but so is every other trans joint by now. Fitting a shift kit isn't rocket science, especially if Jetwreck and I can do it. lol. :cheers:
Isn't boostworx south of city?
Scotty, I must admit fitting the shift was bloody easy, probably the easiest big mod I've ever done to any of my cars. Minimal tools needed and can be done with half a brain! Couldn't believe it was so easy!
Sorry mate, all though it's fairly easy i wont. If it did shag something in your trans or your trans had issues I didnt pick up before fitting the kit and it got worse, I don't won't to be responsible for paying for a new trans for the $200-250 I'd make fitting the kit.
thats why you would go to mv autos!!!!!!!!
Mike said to me that MV designed the kit, seems right to props the workshop. He did the kit and fitted new solenoids when the RS of ours locked us in third.
Big difference in shift, tiptronic does what its told and the lock up clutch is better with more flow to the back of the box.
  • 1 month later...
Here is my dyno sheet,
car is running,
1000cc injectors - bosch
FMIC
highflowed turbo 30/76 running 16 psi. need to get an electronic boosty controller, piss of the T piece.
z32afm
3" zorst with kenobi high flow cat
nistune
denso 260L/hr fuel pump
yellow jacket coil packs
spark plugs gapped.
car is tuned to 98 bp ultimate fuel, not going e85 till there are more pumps.
need my shift kit so bad, car pulls like a train gear changing makes me cry sometimes its that sloppy.....................
OK my car is in at MV automatics, i have a electronic blitz duel stage boost controller in the mail on its way.
Gonna get that fitted and go back to boostworx and get shaun to retune the car for 18psi and hopefully hit 260+
Will keep you guys posted....
  • 4 months later...
I havnt been on here for ages, shift kits done.
1st too 2nd gear change is aggressive i love it, best mod ive done to the car. Running 265s on the rear cause 235s dont hold the road too well with the power im making on boost. I have had a blitz edsbc put in, the car now makes 259.1rwks on 18psi. when i get on my pc i will post up the sheet. Footy is now over for me so catching up with you guys for a cruise will be easier.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
