Hi all,
So I bought a set of wheels off the Internet, xxr 526 18x10.5 +20 and the spokes touch the stanadard brake caliper, only on the front.
So I need about 10-12 mm of clearance so they will fit.
Does anyone know if it's ok to put spacers on the front of an R32 GTR, although then I am going to get guard clearance issues with that size rim. Boo.
As an alternative is there any aftermarket brake setups that would have smaller or more slimline calipers than stock items, obviously without compromising stopping power.
Or should I just take to the caliper with the angle grinder, or maybe the rim. Lol
Any help would be great
Thanks
https://www.sau.com.au/forums/topic/392814-new-rims-dont-fit-r32-gtr/
Hi all,
Thanks
Just cut your losses and get some rims that fit - proper size, proper offset & clearance for the brakes. Its not hard you just have to stop listening to the fitment people.
The Sumitomo calliper is already pretty small as is the rotor it sits on. Arguably too small for the car anyway - so a yet smallet calliper is going to cost money & cause other issues. Better to spend it on good rims instead.
Agreed.
Put on some nice Jap rims with big brake clearance. They will be lighter, stronger then the XXRs, will fit better as they don't need spacers (which are also illegal) and if you ever upgrade to some bigger Brembo, Project Mu, Endless etc. calipers you won't have the same problem again.
Te37s and Lmgt4s even in 17 will give you unbelievable amounts of clearance.
Just about anything in a 17" will give you good clearance on stock callipers. It is just stupid rims with dish that fail. But then again they fail in every other respect so no surprise there. >_<
Hmm,
Disappointing guess I will have to find another set of rims then.
Was just after a nice looking set of rims to get around on on the street with my current cheap Tires.
I already have a set of 18x10 work meister s1 3 piece, but I have a new set of semi slicks to go on them, but don't want to drive around on them all the time and wear the tires out.
Xxr were under a grand delivered from America.
I think I have decided to put some 10mm spacers on the front for now, until I find the right wheels.
Anyone know if it would be a problem having the fronts spaced out and not the rears? Would I have problems with alignment and possibly attessa?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
