hey guys i made a thread about a turbo i just recently bought just recently and from what some SAUers have seen from pictures, they believe it to be a high flowed r32 turbo. i bought it off a guy that was wrecking a rb25det if i can remember and also told me it was auto but have no idea if this is true.could have possibly been high flowed in japan.
a friend of mine is helping me install this on to my r32 gtst (rb20det) and have just run into a few weird things. we believe the rear housing is different to a standard 32 turbo rear housing? and front compressor seems to be different. i know its a long shot but from the pictures below can anyone point out anything they notice that has been changed on this turbo for me? anything unusual at all? also what types of lines it owuld need to be installed into my 32 as one of the water lines seemed not to match up. any recommendations of places i can get liens for this would also be very much appreciated.
Yeah I rekin it's a highflow as well
the back of the comp housing isn't the stock for sure Looks like a t4 core maybe a t3 t4 highflow ?
The inducer on comp housing looks like its bored bigger and had a hone as well to suit bigger comp wheel
Actuator rod looks different to factory 33 as well
As for the lines take it to a shop that does braided lines some autobahns do speed flow fittings and could knock something up for ya
looks a hell of a lot like the VG30DET turbo ive got at home. . . . .whatever it might be just fit it to your motor and get it tuned to suit and enjoy
only a slight highflow as well. maybe stage 1. my old highflow had the whole lip machined out on the exhaust wheel. 25 turbo does'nt have tapped point on compressor housing either
Looks like a plain bearing vg30 turbo, I hope you didn't pay to much for it.
very highly doubt it buddy.
vg30det have 45vs on compressor cover and op6 rear housing which this doesnt have. also rear wheel is heaps bigger than a stock vg30det wheel so yeh don't think so. getting very mixed reactions...i know its a 32 turbo but in terms of high flow specs just not sure so yeh just hoping someone can see something they recognise through compressor and rearhousing.exhaust wheel modifications. thanks everyone for your input but any other input would be appreciated.
can anyone confirm if these lines should be fine for the turbo also.
http://www.ebay.com....=item4aa9d8bf67
Edited by jakez88
It's a mystery bag.
The wheels don't appear to be much bigger then stock.
It's a plain bearing cartridge
It's not an rb20 or 25 cartridge so no point looking for rb specific line kits. Different oil feed needed. The link above doesn't have the right oil feed adapter either.
Honestly, don't waste your time on it.
Ah no worries thanks for letting me know mate. I'll take the turbo somewhere and get some lines made up for it. Can anyone recommend a place in victoria. Just dont know much in terms of fittings, lines and connections.
The centre housing where it connects to the back of the compressor housing looks exactly like the R32 turbo that Hypergear highflowed for me. Compressor housing is R32 turbo, it has the hose connecting up to it which RB25 turbos don't have.
Oh one thing I noticed was where the oil drain pipe goes...thers actually another one on the opposite side...is this normal? You can probably notice it on the 2nd last pic of the first post. Cause at the moment im more concerned about the lines and fittings and what it needs to run properly on my rb20. So its a rb20 high flowed turbo but need to get the connections.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
