Official Cruise: 24.04.04 Macedon (PICTURES)
  • Replies 276
since thursday when I filled up with a full tank till today I've run on the same tank... that includes a trip to sunshine from mill park on friday night and sunday night to see my gf.
All up I've done 496km :) since i filled up n reset my thingy. and i've got a lil bit more to go :( i'll refill on thusday.
yes, well great fuel economy is somethng us N/A-ers take for granted :) downside is lower momentum pushing head back into chair and constant tendancy to see purple GTRs taillights.
there is something wrong... and as many a copper has found out, there is no turbo...
ahahhahahhaha pissa
I didn't realise you had a N/A
did you have trouble keeping up at any time or not (i would think not)
well it took a while for me to accelerate to get to the same speeds you guys were doin, but after that it was relatively easy to keep goin along the same speed.
Coming out of corners was a bit of a bitch coz you guys would shoot off to *80/90/100* and I'd be pudging along gradually increasing speed.
I didn't go with the lead pack for that reason, din hold you fellas up, I stuck with the GTSt's n didn't hold many people up. Altho I did cop a bit of abuse on the CB for havin a slow GTS :) but I gave it bak to em. esp Shivam, who will now NOT be gettin my rear pods. :(
Bah wait till I get my RB25DET in my GTS...
one thing I noticed was that some of the GTSt guys took corners a lot slower than I did so I sorta made up for lack of acceleration out of the corners. mmm love that constant power curve *not* damn license restrictions.
license restirctions?
yeah taking the corners quick can help you keep up quite well
MSPEC kept up with us GTR's at the front in his GTST, mainly due to him taking corners at very high speeds :)
yeah coz I was caught doing some naughty stuff I'm under a 115kw/tonne restriction on my license. :) my car was also impounded n my licesnse suspended for 6 months after which I went back to my L's I was under the old Provisional system back then. When it came time to get my P's again the new 3 year system had kicked in :(
How was everyones fuel consumption? I'm gonna fill up this arvo. I got 475km to this tank since last Thursday till now. I'm pretty impressed considering the cruise...
your joking right?
I filled up at the start... then needed to at the end.
I did about $50 in fuel. approx 300-320 out of a tank at the moment!
God-damn i need a PowerFC :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
