hi guys.i got a r33 fitted with the rb20e motor.what i want to know howstrong are the diff and sideshafts fitted to this model.are they as strong as the turbo skylines' diffs and sideshafts.how do i know if its a r200 diff.my vin plate says rc4.00 does that mean its a r200 diff.if i want to fit a turbo diff do i need the whole casing or jus the intenals.hope anyone can help
https://www.sau.com.au/forums/topic/393575-r33-diff-and-driveshaft-strength/
Don't know about a RB20DE R33, but i'm fairly sure the 25DE and DET diffs/driveshafts are the same?
Few people having trouble with gearboxes on 25DE+T's or high powered RB20DET's, but rarely hear of blown diffs or drive shafts unless it's in BIG power applications.....
Any R200 diff is as strong as any other in the basic aspects (CW&P, centre casting, output halfshafts). In the case of the 2L R33, it's unlikely that the std diff is LSD. And even if it was, VLSDs are pus anyway. Don't look at putting any other centre into your existing housing. Just buy a secondhand mechanical diff already in a housing when you can get one from someone.
I got an R32GTR rear end in my Stagea both for the mechanical LSD and because the 6 x 1 half shafts are thicker than the R33 ones (other advantages are aluminium carriers and twin pot brakes although you will have to change the shocks).
my diff does that.i even done the one wheel up test and itd very hard to turn but when one wheel is on a loose surface like sand and the other on hard surface the one on sand would spin with a light touch on the gas pedal.is that normal for a vlsd
oops sorry man.my diff acts like a lsd.i've jacked up my car n both wheels turn in the same direction.same said to jack up one wheel n if it hard to turn then its a lsd.i've done that test too n its hard to turn the wheel.do viscous lsd work when the wheels turn slow cause when one wheel is on a hard surface n the other on sand the one on sand starts to spin n no power goes to the other wheel
<br />My diff is a piece of shit, limited slip my f**ken ass.<br />
<br /><br /><br />
I've just been driving mine for the first time since putting the helical centre in it. As far as I'm concerned, the VLSD that was in it before was effectively open. I now have to learn to drive the car again, because everything it does is different!
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
